Sorry to be such a newbie! I'm testing EFA and run into issues that I can't readily find answers for, either in the EFA or the MailScanner docs.
I can't see an obvious cron job for the daily reports. I assume that it's to run at midnight? I'd actually like to find where this is set and change the time of day, but in poking around I'm not finding what I'm looking for.
Danita
Daily Reports
Re: Daily Reports
/etc/cron.daily/mailwatch
It fires off when cron processes cron.daily which is controlled in /etc/anacrontab
I would recommend if you want to change this simply moving mailwatch out of /etc/cron.daily and creating your own crontab to run it when you want it to run.
