eFa not recognizing VG FreePE after installation
Posted: 10 Apr 2020 20:15
Hi guys,
I've installed Centos7_minimal and configured LVM (100GB PV, 1 VG, 6 LVs). Then I ran..
The whole process was quick and smooth, ending with no errors and rebooting the VM. After this, the "new" console dashboard appeared and I've tried to extend the logical volumes in order to match my needs, but discovered that almost 80Gigs of free physical extents where not there.
How can I force eFa to refresh the available free PE in the VG?
Regards,
Nyquist
curl -sSL https://install.efa-project.org | bashCode: Select all
--- Volume group ---
VG Name vg01
System ID
Format lvm2
Metadata Areas 1
Metadata Sequence No 7
VG Access read/write
VG Status resizable
MAX LV 0
Cur LV 6
Open LV 6
Max PV 0
Cur PV 1
Act PV 1
VG Size 16.00 GiB
PE Size 4.00 MiB
Total PE 4097
Alloc PE / Size 4096 / 16.00 GiB
Free PE / Size 1 / 4.00 MiBRegards,
Nyquist
