eFa 4.0.2 - no messages inserted into mailscanner database
Posted: 13 Feb 2020 11:53
I've upgraded eFa 3.0.26 to eFa 4.0.2 and in mailwatch no messages are being recorded into database. So far I've done:
- tested id user and password had privileges on the database (it had)
- put maxmind license
- ssl_error_log (no errors)
- mailwatch upgrade.php gives the following summary ()
- MailScanner --lint (no errors)
Any ideas what could be happening ?
thanks in advance
*** ERROR/WARNING SUMMARY ***
conf.php: optional configuration entry "RPC_PORT" is missing, needed if RPC_ONLY mode is enabled
conf.php: optional configuration entry "RPC_SSL" is missing, needed if RPC_ONLY mode is enabled
conf.php: optional configuration entry "RPC_REMOTE_SERVER" is missing, needed to show number of mails in postfix queues on remote server (RPC)
conf.php: optional configuration entry "VIRUS_REGEX" is missing, needed in distributed setup
conf.php: optional configuration entry "LDAP_BIND_PREFIX" is missing, needed when using LDAP authentication
conf.php: optional configuration entry "LDAP_BIND_SUFFIX" is missing, needed when using LDAP authentication
conf.php: optional configuration entry "EXIM_QUEUE_IN" is missing, needed only if using Exim as MTA
conf.php: optional configuration entry "EXIM_QUEUE_OUT" is missing, needed only if using Exim as MTA
conf.php: optional configuration entry "PWD_RESET_FROM_NAME" is missing, needed if Password Reset feature is enabled
conf.php: optional configuration entry "PWD_RESET_FROM_ADDRESS" is missing, needed if Password Reset feature is enabled
conf.php: optional configuration entry "MAILQ" is missing, needed when using Exim or Sendmail to display the inbound/outbound mail queue lengths
conf.php: optional configuration entry "MAIL_SENDER" is missing, needed if you use Exim or Sendmail Queue
conf.php: optional configuration entry "SESSION_NAME" is missing, needed if experiencing session conflicts
conf.php: optional configuration entry "SENDMAIL_QUEUE_IN" is missing, needed only if using Sendmail as MTA
conf.php: optional configuration entry "SENDMAIL_QUEUE_OUT" is missing, needed only if using Sendmail as MTA
conf.php: optional configuration entry "MAILWATCH_SMTP_HOSTNAME" is missing, needed only if you use a remote SMTP server to send MailWatch emails
conf.php: optional configuration entry "ALLOW_NO_USER_DOMAIN" is missing, allow usernames not in mail format for domain admins and regular users
conf.php: optional configuration entry "ENABLE_SUPER_DOMAIN_ADMINS" is missing, allows domain admins to change domain admins from the same domainAny ideas what could be happening ?
thanks in advance
