stop incoming mail
enriluis
stop incoming mail
Post by enriluis »
Hello all, i have running EFA, recently my users are receiving some unwanted mails, the header look like this. How i can stop incoming mail that are using other domains and address, i know this is basic protection but by some reason recentily it happen
Received-SPF: Pass (sender SPF authorized) identity=mailfrom; client-ip=66.96.186.10; helo=bosmailout10.eigbox.net; envelope-from=srs0=1n7koh=op=harryscollision.com=payments@eigbox.net; receiver=enrique@bicsa.co.cu
DMARC-Filter: OpenDMARC Filter v1.3.2 temis.bicsa.co.cu 1BD37200F4
Authentication-Results: temis.bicsa.co.cu; dmarc=none (p=none dis=none) header.from=infomed.sld.cu
Authentication-Results: temis.bicsa.co.cu; spf=pass smtp.mailfrom=SRS0=1N7KoH=OP=harryscollision.com=payments@eigbox.net
DKIM-Filter: OpenDKIM Filter v2.11.0 temis.bicsa.co.cu 1BD37200F4
X-Greylist: delayed 00:30:03 by SQLgrey-1.8.0
Received: from bosmailout10.eigbox.net (bosmailout10.eigbox.net [66.96.186.10])
by temis.bicsa.co.cu (Postfix) with ESMTPS id 1BD37200F4
for <enrique@bicsa.co.cu>; Thu, 6 Dec 2018 08:39:32 -0500 (CST)
Received: from bosmailscan05.eigbox.net ([10.20.15.5])
by bosmailout10.eigbox.net with esmtp (Exim)
id 1gUtPC-0007HS-9y
for enrique@bicsa.co.cu; Thu, 06 Dec 2018 08:09:26 -0500
Received: from [10.115.3.32] (helo=bosimpout12)
by bosmailscan05.eigbox.net with esmtp (Exim)
id 1gUtPC-0002Hd-0a
Received: from bosauthsmtp01.yourhostingaccount.com ([10.20.18.1])
by bosimpout12 with
id 8d9N1z00B01P9Sa01d9RUM; Thu, 06 Dec 2018 08:09:25 -0500
X-EN-SP-DIR: OUT
X-EN-SP-SQ: 1
Received: from bba187932.alshamil.net.ae ([217.165.76.226]:55759 helo=10.2.0.8)
by bosauthsmtp01.eigbox.net with esmtpa (Exim)
id 1gUtP6-0007ja-Ju
for enrique@bicsa.co.cu; Thu, 06 Dec 2018 08:09:22 -0500
Date: Thu, 06 Dec 2018 17:09:15 +0400
From: Oscar Tariche <otariche@infomed.sld.cu> <payments@harryscollision.com>
To: enrique@bicsa.co.cu
Message-ID: <3380624529383017795.06FECBB25E15F7F1@bicsa.co.cu>
Subject: Oscar Tariche Recordatorio de pago
MIME-Version: 1.0
Content-Type: multipart/mixed; boundary="----=_Part_18463_1520642677.4289726652873806964"
X-EN-UserInfo: 578541fe7d0eb9939a5030e987064c0f:931c98230c6409dcc37fa7e93b490c27
X-EN-AuthUser: payments@harryscollision.com
Sender: Oscar Tariche <otariche@infomed.sld.cu> <payments@harryscollision.com>
X-EN-OrigIP: 217.165.76.226
X-EN-OrigHost: bba187932.alshamil.net.ae
srs0=1n7koh=op=harryscollision.com=payments@eigbox.net [Add to Whitelist | Add to Blacklist]
