EFA keeps working but the web interface keep telling me cannot connect or unreachable. Solved by doing a /etc/init.d/httpd restart
the /var/log/httpd/error.log file says:
[notice] child pid 53446 exit signal Segmentation fault
Any ideas? I already did a yum update.This happened twice in the last 24h
web interface unreachable 2-3 times a day
Re: web interface unreachable 2-3 times a day
What's happening during that time? Is the system running out of memory?
nope. the system resources for EFA are actually over-sized.
To give you an idea, this EFA instance has about an average of 150 emails per working day and 20 per Sat/Sun.
Its a VM with 8GB RAM and 2CPUs.
The problem has recently started and hasn't happened again since I posted here. I was rather curious if anyone has experienced anything similar or has any ideas where I could poke and prod to see if I can find the source of the problem.
can you run "top" while the web interface is non responsive?
I've previously seen that when I was training the bayes classifier with spam, the web interface would be completely unresponsive until it was finished.
Is your mysql instance busy?
what does "iostat 1" show you during those non responsive times? do you see a high % of iowait?
you may consider running "iotop" to see if it is disk related pauses as well.
Thanks for the pointers. I will do all of that and reply if / when it happens again.
This information might help us figure out what is going on/going wrong.
On the other hand, maybe you'll never see the problem again
Just to add a "me too" comment. All 4 of my EFA servers (2 incoming, 2 outgoing) experienced the same condition once overnight on the same date as the original post. I restarted httpd when I came in the office and the problem has never occurred again. We have had storms and power/network outages so I attributed the problem to that and didn't investigate further.
unrepeatable problems are among the hardest to solve, much less diagnose.
