I am currently using a home brewed Exim/Spamassassin filter, it works well but provides no way for end-users to release spam, review logs etc.
Is it a horrible idea to spin up a Centos 7 VM & run https://raw.githubusercontent.com/E-F-A ... evbuild.sh
v4
Re: v4
Not necessarily you can help me out
The first thing you'll notice on a successful build that some things are missing. You would need to add them or handle yourself (EFA-Configure, for example...overhauling that...)
Also, you'll be presented with an EFAInit GUI. This is incomplete and will not complete your setup. Bypass it by running the command line version instead, and then switch from EFAInit in Apache back to MailWatch.
You will have a working system at this point, albeit a very bare one.
Re: v4
Thanks Shawn - I'll keep the community informed as I make progress.
Re: v4
Hi Shawn, would you suggest not switching to v4 yet to the less technically savvy of us?shawniverson wrote: ↑23 Jul 2018 21:46 Not necessarily you can help me out
You will benefit from PhenGold and have a working system at this point, albeit a very bare one.
