Dear guys
I'm running old version of Efa.
When I try to update with option 14 I receive this notification
Update to 3.0.1.5 is pending on spamfilter.gruppo.local.
Your system has an updated kernel, but you are not running
on the latest kernel. Please restart your system and run
EFA-Update after restart.
But I verified kernel running and
[sysadmin@spamfilter ~]$ uname -sr
Linux 2.6.32-696.23.1.el6.x86_64
[sysadmin@spamfilter ~]$ rpm -q kernel
kernel-2.6.32-696.20.1.el6.x86_64
kernel-2.6.32-696.23.1.el6.x86_64
This is the message after choice into menù Efa:
[EFA] : 14
[EFA] Good you are root
[EFA] Starting update to EFA-3.0.2.6
Setting up Update Process
* EFA: dl.efa-project.org
* base: it.centos.contactlab.it
* extras: it.centos.contactlab.it
* updates: it.centos.contactlab.it
No Packages marked for Update
Could someone help me please?
Best regards
problem with update version
Re: problem with update version
Did you reboot your system?
oh yeah, of course, without results.
this'is a vm on Xen
this'is a vm on Xen
Version installed: 3.0.1.4
I'm sure to boot with last kernel installed.
Is't a bug for this version? Can I apply a manual upgrade?
RESOLVED
into
EFA find kernel information and not
I've changed path and works fine!
into
/usr/local/sbin/EFA-Update -update
/boot/grub/menu.lst
/etc/grub.conf
