Letsencrypt not installing/renewing on EFA 3.0.2.6
Posted: 11 Mar 2018 17:59
by jogomes
Hi to all,
:angry-banghead:
I searched and found some similarities but no actual solution or problem like this.
I have a EFA that has a letsencrypt 'manual' installation, and I wanted to change it to the automated one from the menu.
So this morning I tried to renew my cert from my EFA, but I cannot it keeps telling me that there is no Virtual Server running on port 80.
Despite some efforts, even activated the Virtualhost on port 80, nothing seems to work.
When I try to install/renew, it does an update of the Python to 3.4 version (?). Found somewhere that this can be a problem to certbot ??? But no solution found, or I didn't apply it to this system, since it has an automated procedure, and I want not to change it.
I'm not doing it again since I restored a snapshot and copied back the settings back to the production server since there were some emails that already entered and I want to keep it on history.
So, EFA is running with the 'old' cert, and I have 15 days to solve this issue until it expires.
Its not a FW problem, neither a NAT.
I tried the manual and automated ways, all failed with the same issue.
Looking for some help from you guys.
Stay sharp and well.
JG
Re: Letsencrypt not installing/renewing on EFA 3.0.2.6
Posted: 17 Apr 2018 23:00
by theEFAmenace
Same problem here, any solution ?
Posted: 17 Apr 2018 23:30
by theEFAmenace
I ended up adding a virtual host at the end of the httpd.conf - uncommented the last block and updated the details with my own.
Worked like a charm.
Posted: 02 May 2018 12:40
by jamerson
Do you have port 80/443 nat to your EFA ?
Posted: 13 Jun 2018 16:34
by aetadmin
I just had this problem too; my let's encrypt (letsencrypt) was not renewing the cert. I'm sure this is because I have the force ssl redirect enabled. So, I managed to fix it by the following:
edit the file /etc/httpd/conf.d/redirectssl.conf
and change it to this:
RewriteEngine On
RewriteCond %{SERVER_PORT} 80
RewriteCond %{REQUEST_URI} !^/\.well\-known/acme\-challenge/
#RewriteCond %{HTTPS} !=on
RewriteRule ^/?(.*) https://%{SERVER_NAME}/$1 [R,L]
Notice that I also commented out the RewriteCond to check for HTTPS is not on. This will still redirect all HTTP requests, just not the ones for letsencrypt.
Posted: 14 Jun 2018 09:08
:clap: Good tip!
Posted: 14 Jun 2018 21:43
Posted: 15 Jun 2018 23:36
by jamerson
Hi Guys,
after adding this line
RewriteEngine On
[*]RewriteCond %{SERVER_PORT} 80
Whcih command we have to run to renew the SSL or it will do it automatically ?
