Mailscanner update problem
arsmage
Post by arsmage »
I have an issue after the EFA-MS-Update ran recently. After the most recent update it tries to load /etc/init.d/MailScanner and fails. I examined the contents of /etc/init.d and found that it appear the script was updated yesterday with a new name, all lowercase.
lrwxrwxrwx 1 root root 33 Feb 5 10:23 mailscanner -> /usr/lib/MailScanner/init/ms-init
I checked the contents of EFA-MS-Update and there are places where it uses /etc/init.d/mailscanner and others where it uses /etc/init.d/MailScanner.
-rwxr--r-- 1 root root 9888 Feb 5 10:24 /usr/local/sbin/EFA-MS-Update
/etc/init.d/mailscanner reload #> /dev/null 2>&1
/etc/init.d/mailscanner stop
/etc/init.d/mailscanner start
/etc/init.d/MailScanner reload #> /dev/null 2>&1
/etc/init.d/MailScanner stop
/etc/init.d/MailScanner start
After running 'mailscanner status' it appears that the process is running, just now there is a potentially misleading failure.
Log entry below...
MailScanner restarted with process id 11921
--2018-02-06 03:43:13-- http://dl.efa-project.org/MailScanner/p ... sites.conf
Connecting to xxx.xxx.xxx.xxxx:80... connected.
Proxy request sent, awaiting response... 200 OK
Length: 12634 (12K) [application/octet-stream]
Remote file is newer, retrieving.
Connecting to 172.30.32.199:80... connected.
Saving to: “phishing.safe.sites.conf”
0K .......... .. 100% 146K=0.08s
2018-02-06 03:43:14 (146 KB/s) - “phishing.safe.sites.conf” saved [12634/12634]
It completed okay.
/usr/local/sbin/EFA-MS-Update: line 173: /etc/init.d/MailScanner: No such file or directory
MailScanner reload failed - Retrying...
/usr/local/sbin/EFA-MS-Update: line 176: /etc/init.d/MailScanner: No such file or directory
Stopping MailScanner...
/usr/local/sbin/EFA-MS-Update: line 181: /etc/init.d/MailScanner: No such file or directory
Waiting for a minute...
Attemping to start MailScanner...
/usr/local/sbin/EFA-MS-Update: line 185: /etc/init.d/MailScanner: No such file or directory
Re: Mailscanner update problem
viewtopic.php?f=13&t=2892
/clickable links gives me an happy face :D
:lol:
henk wrote: 07 Feb 2018 09:03 viewtopic.php?f=13&t=2892
