Problem with vps
mreinder
Problem with vps
Post by mreinder »
Good morning everyone,
First to say A Merry Christmas.
But now the problem. I'm running efa on a vps hosting and they only support centos 7.4.
Efa runs only on centos 6. Is it possible to start using the efa 4 beta or is this not possible?
Re: Problem with vps
My suggestion? Choose another vps provider that will allow you to use the OS of your choice.
I might be able to get an alpha version of v4 ready. Definitely not beta yet.
