SSL after upgrade to 3.0.2.5
ayh20
Post by ayh20 »
I found this post that says there has been changes to SSL setup/config viewtopic.php?f=13&t=2733&p=10715&hilit=ssl#p10715
For those of us who are technologically challenged :? ... can anyone give us some instructions on what needs to be done to get the SSL setup working again ?
Please ..... :roll:
TheGr8Wonder
Re: SSL after upgrade to 3.0.2.5
Post by TheGr8Wonder »
ayh20 - based on your other post, is it just webmin that is broken for you, or other components as well?
ayh20
Post by ayh20 »
Mailwatch and webmin
ayh20
Post by ayh20 »
So after reading the instructions in that post i have gotten access to webwin.
nano /etc/webmin/miniserv.conf
Change ssl=1 to ssl=0
/etc/init.d/webmin restart
/etc/init.d/httpd restart
Connect using http://server:10000
Webmin -> Webmin Configuration -> SSL Encryption
Added the old cert and key via the UI.
Servers ->Apache Webserver -> Existing hosts -> Virtual Server (443) -> SSL options
Selected the old cert and key in /etc/pki/tls/certs and /etc/pki/tls/private respectivly
Then restarted apache ... tested mail watch and turned SSL back on for webmin.
Seems to be OK ... is there anything i've missed ?
cybernol
Post by cybernol »
Very annoying that the webserver goes down after the update.
no easy to see whats wrong.
Yes I had my own certificate
Solved by enable Let's Encript and then disable again.
