address verify expire time modify
hiandras
Post by hiandras »
postconf -d shows:
address_verify_negative_expire_time = 3d
address_verify_positive_expire_time = 31d
I think these are some default values and they are way too much.
How can I modify them? (I cannot find them in the postfix cf files.
Tried to add them, but won't make any difference)
Regards,
Andras
Re: address verify expire time modify
After you add them, you have to restart postfix.
hiandras
Post by hiandras »
It does not work for me. :(
I put:
address_verify_negative_expire_time = 1d
address_verify_negative_refresh_time = 2h
address_verify_positive_expire_time = 1d
address_verify_positive_refresh_time = 4h
to the end of /etc/postfix/main.cf
then run "service postfix reload" (also tried with restart).
But the values does not change, when I list in postconf -d.
Regards,
Andras
What are you trying to do, and are you even using address verification in postfix?
hiandras
Post by hiandras »
Yes, I use address verification.
I added "reject_unverified_recipient" to the "smtpd_recipient_restrictions =" string and put "unverified_recipient_reject_code = 550" at the and of mail.cf.
I relay the mails to an exchange server and efa still excepts mail for addresses which are deleted more than 10 days ago.
I want them rejected by efa.
Regards,
Andras
I admit, this one has me a bit baffled. I will turn on address verification on mine and see if I can come to the same conclusion.
hiandras
Post by hiandras »
Sorry to bug you! Have you came to the same conclusion?
Do you have any idea, how to overcome this?
Regads,
Andras
