We use 2x Servers running WIndows Server 2012 R2 Hosting Hyper-V VM's.
We dont have local user as a login, only domain as we have an ad, 2x dc's.
is there a work around for the initial setup.
It mounts perfectly but im faced with :
-- welcome to EFA-3.0.2.5 ---
Https://www.efa-project.org
First time login: root/EfaPr0j3ct
Host1-Ser Login:
Ive tried all the usual and current admin cred's.
I have even added local creds
all to no avail
What give, to fail at the second hurdle is a bit sad.
Install
Re: Install
https://wiki.efa-project.org/doku.php?i ... figuration
According to the above, you should use "root" as the login and "EfaPr0j3ct" as a password for the initial setup.
Did you try that?
Did you try that?
Re: Install
Cheers Buddy it worked a treatpdwalker wrote: ↑13 Oct 2017 08:33 https://wiki.efa-project.org/doku.php?i ... figuration
Did you try that?
It was about the only thing I didn't try. before turning off the light Ill get my coat, lol.
Well i'm at the web interface and i must say it looks impressive, certainly has the commercial look and feel about it.
Im going on holiday from this monday for a week and after that time ill be looking to use this to replace our current provider.
