Is there a way of exporting and importing the Whitelist from the Mailscanner GUI?
jogomes
Post by jogomes »
HI, I had to rebuild the EFA VM, since the other had and disk error that cannot be recovered totally.
Now, almost everything is in place except the huge Whitelists that we had on the previous server, the ones that are built using the release of emails or manually.
I still can access it, just it can't be used anymore.
Does anyone have any hints for accomplish this task? other than do it manually.
Regards.
JG
Re: Is there a way of exporting and importing the Whitelist from the Mailscanner GUI?
Might be of interest. This definitely will port over the black and whitelists as well.
viewtopic.php?f=5&t=2703
