Automatically import ALL AD users in version 3.0.2.3
Posted: 03 Jul 2017 21:21
I would like to automatically import ALL AD users in version 3.0.2.3
I can add AD users by manually having them login but I want to import them automatically from AD so if I add a new user in AD within a set schedule they will appear in EFA /Mailwatch user management.
an article I found says to update mailwatch_ldap_synch.sh
I did not see the file so I created it
I found this code but it does not seem to work, what am I missing? I am not sure which MSQL DB / user and password to use. Also, is there someplace I need to call this script?
#!/bin/bash
# mailwatch_ldap_sync.sh: A shell script to import Microsoft Exchange Users from
# Active Directory into the MailWatch user database.
# Version: 1.1
# Copyright (C) 2012 Daniel Himler <d.himler@netsense.at>
# This program is free software; you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation; either version 2 of the License, or
# (at your option) any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with this program; if not, write to the Free Software
# Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
# CHANGES
# Version 1.1
# - Concatenate multiline results returned by ldapsearch
# - Decode Base64 strings returned by ldapsearch
# - Fix lookups of DNs with commas in their name
# - Exclude Exchange 2010 system mailboxes
# - Use mktemp for temporary file creation
# Version 1.0
# - Initial Release
# Configuration #
LDAP_URI="192.168.111.32:389"
LDAP_BASE="DC=mydomain,DC=org"
LDAP_USER=" myserviceaccount@mydomain.org"
LDAP_PASS="mysecretpass"
MYSQL_HOST="localhost"
MYSQL_PORT="3306"
MYSQL_NAME="mailscanner"
MYSQL_USER="mailwatch"
MYSQL_PASS="secret"
##################### DON'T TOUCH ANYTHING BELOW THIS LINE #####################
TEMPFILE="$(mktemp)"
LDAP_USERS="$(ldapsearch -LLL -H "$LDAP_URI" -D "$LDAP_USER" -w "$LDAP_PASS" -x -b "$LDAP_BASE" \
(objectClass=user)
(proxyAddresses=*)
"proxyAddresses" |
sed -n '1 {h;$!d}; ${x;s/\n //g;p}; /^ /{H;d}; /^ /!{x;s/\n //g;p}' |
sed -ne "s/^proxyAddresses: SMTP:\(.*\)/\1/p" |
grep -Ev "DiscoverySearchMailbox|FederatedEmail|SystemMailbox" | sort)"
[ -f "$TEMPFILE" ] && rm -f "$TEMPFILE"
for USER in ${LDAP_USERS}; do
unset DN FULLNAME ALIASES GROUP_ALIASES TYPE REPORT SPAMSCORE HIGHSPAMSCORE NOSCAN RECIPIENT RESULT
USER="$(echo "$USER" | sed -e "s/\(.*\)/\L\1/")"
RESULT="$(ldapsearch -LLL -H "$LDAP_URI" -D "$LDAP_USER" -w "$LDAP_PASS" -x -b "$LDAP_BASE" \
"(proxyAddresses=SMTP:$USER)" \
"dn" "displayName" "proxyAddresses" | sed -n '1 {h;$!d}; ${x;s/\n //g;p}; /^ /{H;d}; /^ /!{x;s/\n //g;p}')"
echo "$RESULT" | grep -qs "dn:: "
if [ "$?" -eq "0" ]; then
DN="$(echo "$RESULT" | sed -ne "s/^dn:: \(.*\)/\1/p" | base64 -d)"
else
DN="$(echo "$RESULT" | sed -ne "s/^dn: \(.*\)/\1/p")"
fi
DN="$(echo "$DN" | sed -e "s/\\\,/\\\\\\\\,/g")"
echo "$RESULT" | grep -qs "displayName:: "
FULLNAME="$(echo "$RESULT" | sed -ne "s/^displayName:: \(.*\)/\1/p" | base64 -d)"
else
FULLNAME="$(echo "$RESULT" | sed -ne "s/^displayName: \(.*\)/\1/p")"
fi
ALIASES="$(echo "$RESULT" | sed -ne "s/^proxyAddresses: smtp:\(.*\)/\1/p")"
GROUP_ALIASES="$(ldapsearch -LLL -H "$LDAP_URI" -D "$LDAP_USER" -w "$LDAP_PASS" -x -b "$LDAP_BASE" \
"(&(objectClass=group)(proxyAddresses=*)(member=$DN))" \
"proxyAddresses" | sed -n '1 {h;$!d}; ${x;s/\n //g;p}; /^ /{H;d}; /^ /!{x;s/\n //g;p}' | sed -ne "s/^proxyAddresses: [sS][mM][tT][pP]:\(.*\)/\1/p")"
eval $(echo "SELECT type, quarantine_report, spamscore, highspamscore, noscan, quarantine_rcpt FROM users WHERE username = '$USER';" |
mysql -B -N --host="$MYSQL_HOST" --port="$MYSQL_PORT" --user="$MYSQL_USER" --password="$MYSQL_PASS" "$MYSQL_NAME" |
sed -e "s/\(\S*\)\s\(\S*\)\s\(\S*\)\s\(\S*\)\s\(\S*\)\s\(\S*\)/TYPE=\1 REPORT=\2 SPAMSCORE=\"\3\" HIGHSPAMSCORE=\"\4\" NOSCAN=\"\5\" RECIPIENT=\"\6\"/")
USER="$(echo "$USER" | sed -e "s/@/\\\@/g")"
[ -n "$TYPE" ] || TYPE="U"
[ -n "$REPORT" ] || REPORT="0"
[ -n "$SPAMSCORE" ] || SPAMSCORE="0"
[ -n "$HIGHSPAMSCORE" ] || HIGHSPAMSCORE="0"
[ -n "$NOSCAN" ] || NOSCAN="0"
[ -n "$RECIPIENT" ] || RECIPIENT="NULL"
[ "$RECIPIENT" != "NULL" ] && RECIPIENT="'$RECIPIENT'"
RECIPIENT="$(echo "$RECIPIENT" | sed -e "s/@/\\\@/g")"
echo "REPLACE INTO users (username, password, fullname, type, quarantine_report, spamscore, highspamscore, noscan, quarantine_rcpt)
VALUES ('$USER', NULL, '$FULLNAME', '$TYPE', $REPORT, $SPAMSCORE, $HIGHSPAMSCORE, $NOSCAN, $RECIPIENT);" >> "$TEMPFILE"
echo "DELETE FROM user_filters WHERE username = '$USER';" >> "$TEMPFILE"
for ALIAS in ${ALIASES} ${GROUP_ALIASES}; do
ALIAS="$(echo "$ALIAS" | sed -e "s/\(.*\)/\L\1/" -e "s/@/\\\@/g")"
echo "INSERT INTO user_filters (username, filter, active) VALUES ('$USER', '$ALIAS', 'Y');" >> "$TEMPFILE"
done
done
MYSQL_USERS="$(echo "SELECT username FROM users WHERE password IS NULL;" |
mysql --host "$MYSQL_HOST" \
--port="$MYSQL_PORT" \
--user="$MYSQL_USER" \
--password="$MYSQL_PASS" \
--skip-column-names "$MYSQL_NAME")"
for USER in ${MYSQL_USERS}; do
unset DN RESULT
RESULT="$(ldapsearch -LLL -H "$LDAP_URI" -D "$LDAP_USER" -w "$LDAP_PASS" -x -b "$LDAP_BASE" "(proxyAddresses=SMTP:$USER)" "dn" | sed -n '1 {h;$!d}; ${x;s/\n //g;p}; /^ /{H;d}; /^ /!{x;s/\n //g;p}')"
else
fi
if [ "$DN" == "" ]; then
echo "DELETE FROM users WHERE username = '$USER';" >> "$TEMPFILE"
fi
done
mysql --host="$MYSQL_HOST" --port="$MYSQL_PORT" --user="$MYSQL_USER" --password="$MYSQL_PASS" "$MYSQL_NAME" < "$TEMPFILE"
RETVAL="$?"
rm -f "$TEMPFILE"
exit "$RETVAL"
