Automatically import ALL AD users in version 3.0.2.3
dsheetz
Post by dsheetz »
I would like to automatically import ALL AD users in version 3.0.2.3
I can add AD users by manually having them login but I want to import them automatically from AD so if I add a new user in AD within a set schedule they will appear in EFA /Mailwatch user management.
an article I found says to update mailwatch_ldap_synch.sh
I did not see the file so I created it
I found this code but it does not seem to work, what am I missing? I am not sure which MSQL DB / user and password to use. Also, is there someplace I need to call this script?
#!/bin/bash
# mailwatch_ldap_sync.sh: A shell script to import Microsoft Exchange Users from
# Active Directory into the MailWatch user database.
# Version: 1.1
# Copyright (C) 2012 Daniel Himler <d.himler@netsense.at>
# This program is free software; you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation; either version 2 of the License, or
# (at your option) any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with this program; if not, write to the Free Software
# Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
# CHANGES
# Version 1.1
# - Concatenate multiline results returned by ldapsearch
# - Decode Base64 strings returned by ldapsearch
# - Fix lookups of DNs with commas in their name
# - Exclude Exchange 2010 system mailboxes
# - Use mktemp for temporary file creation
# Version 1.0
# - Initial Release
# Configuration #
LDAP_URI="192.168.111.32:389"
LDAP_BASE="DC=mydomain,DC=org"
LDAP_USER=" myserviceaccount@mydomain.org"
LDAP_PASS="mysecretpass"
MYSQL_HOST="localhost"
MYSQL_PORT="3306"
MYSQL_NAME="mailscanner"
MYSQL_USER="mailwatch"
MYSQL_PASS="secret"
##################### DON'T TOUCH ANYTHING BELOW THIS LINE #####################
TEMPFILE="$(mktemp)"
LDAP_USERS="$(ldapsearch -LLL -H "$LDAP_URI" -D "$LDAP_USER" -w "$LDAP_PASS" -x -b "$LDAP_BASE" \
(objectClass=user)
(proxyAddresses=*)
"proxyAddresses" |
sed -n '1 {h;$!d}; ${x;s/\n //g;p}; /^ /{H;d}; /^ /!{x;s/\n //g;p}' |
sed -ne "s/^proxyAddresses: SMTP:\(.*\)/\1/p" |
grep -Ev "DiscoverySearchMailbox|FederatedEmail|SystemMailbox" | sort)"
[ -f "$TEMPFILE" ] && rm -f "$TEMPFILE"
for USER in ${LDAP_USERS}; do
unset DN FULLNAME ALIASES GROUP_ALIASES TYPE REPORT SPAMSCORE HIGHSPAMSCORE NOSCAN RECIPIENT RESULT
USER="$(echo "$USER" | sed -e "s/\(.*\)/\L\1/")"
RESULT="$(ldapsearch -LLL -H "$LDAP_URI" -D "$LDAP_USER" -w "$LDAP_PASS" -x -b "$LDAP_BASE" \
"(proxyAddresses=SMTP:$USER)" \
"dn" "displayName" "proxyAddresses" | sed -n '1 {h;$!d}; ${x;s/\n //g;p}; /^ /{H;d}; /^ /!{x;s/\n //g;p}')"
echo "$RESULT" | grep -qs "dn:: "
if [ "$?" -eq "0" ]; then
DN="$(echo "$RESULT" | sed -ne "s/^dn:: \(.*\)/\1/p" | base64 -d)"
else
DN="$(echo "$RESULT" | sed -ne "s/^dn: \(.*\)/\1/p")"
fi
DN="$(echo "$DN" | sed -e "s/\\\,/\\\\\\\\,/g")"
echo "$RESULT" | grep -qs "displayName:: "
FULLNAME="$(echo "$RESULT" | sed -ne "s/^displayName:: \(.*\)/\1/p" | base64 -d)"
else
FULLNAME="$(echo "$RESULT" | sed -ne "s/^displayName: \(.*\)/\1/p")"
fi
ALIASES="$(echo "$RESULT" | sed -ne "s/^proxyAddresses: smtp:\(.*\)/\1/p")"
GROUP_ALIASES="$(ldapsearch -LLL -H "$LDAP_URI" -D "$LDAP_USER" -w "$LDAP_PASS" -x -b "$LDAP_BASE" \
"(&(objectClass=group)(proxyAddresses=*)(member=$DN))" \
"proxyAddresses" | sed -n '1 {h;$!d}; ${x;s/\n //g;p}; /^ /{H;d}; /^ /!{x;s/\n //g;p}' | sed -ne "s/^proxyAddresses: [sS][mM][tT][pP]:\(.*\)/\1/p")"
eval $(echo "SELECT type, quarantine_report, spamscore, highspamscore, noscan, quarantine_rcpt FROM users WHERE username = '$USER';" |
mysql -B -N --host="$MYSQL_HOST" --port="$MYSQL_PORT" --user="$MYSQL_USER" --password="$MYSQL_PASS" "$MYSQL_NAME" |
sed -e "s/\(\S*\)\s\(\S*\)\s\(\S*\)\s\(\S*\)\s\(\S*\)\s\(\S*\)/TYPE=\1 REPORT=\2 SPAMSCORE=\"\3\" HIGHSPAMSCORE=\"\4\" NOSCAN=\"\5\" RECIPIENT=\"\6\"/")
USER="$(echo "$USER" | sed -e "s/@/\\\@/g")"
[ -n "$TYPE" ] || TYPE="U"
[ -n "$REPORT" ] || REPORT="0"
[ -n "$SPAMSCORE" ] || SPAMSCORE="0"
[ -n "$HIGHSPAMSCORE" ] || HIGHSPAMSCORE="0"
[ -n "$NOSCAN" ] || NOSCAN="0"
[ -n "$RECIPIENT" ] || RECIPIENT="NULL"
[ "$RECIPIENT" != "NULL" ] && RECIPIENT="'$RECIPIENT'"
RECIPIENT="$(echo "$RECIPIENT" | sed -e "s/@/\\\@/g")"
echo "REPLACE INTO users (username, password, fullname, type, quarantine_report, spamscore, highspamscore, noscan, quarantine_rcpt)
VALUES ('$USER', NULL, '$FULLNAME', '$TYPE', $REPORT, $SPAMSCORE, $HIGHSPAMSCORE, $NOSCAN, $RECIPIENT);" >> "$TEMPFILE"
echo "DELETE FROM user_filters WHERE username = '$USER';" >> "$TEMPFILE"
for ALIAS in ${ALIASES} ${GROUP_ALIASES}; do
ALIAS="$(echo "$ALIAS" | sed -e "s/\(.*\)/\L\1/" -e "s/@/\\\@/g")"
echo "INSERT INTO user_filters (username, filter, active) VALUES ('$USER', '$ALIAS', 'Y');" >> "$TEMPFILE"
done
done
MYSQL_USERS="$(echo "SELECT username FROM users WHERE password IS NULL;" |
mysql --host "$MYSQL_HOST" \
--port="$MYSQL_PORT" \
--user="$MYSQL_USER" \
--password="$MYSQL_PASS" \
--skip-column-names "$MYSQL_NAME")"
for USER in ${MYSQL_USERS}; do
unset DN RESULT
RESULT="$(ldapsearch -LLL -H "$LDAP_URI" -D "$LDAP_USER" -w "$LDAP_PASS" -x -b "$LDAP_BASE" "(proxyAddresses=SMTP:$USER)" "dn" | sed -n '1 {h;$!d}; ${x;s/\n //g;p}; /^ /{H;d}; /^ /!{x;s/\n //g;p}')"
else
fi
if [ "$DN" == "" ]; then
echo "DELETE FROM users WHERE username = '$USER';" >> "$TEMPFILE"
fi
done
mysql --host="$MYSQL_HOST" --port="$MYSQL_PORT" --user="$MYSQL_USER" --password="$MYSQL_PASS" "$MYSQL_NAME" < "$TEMPFILE"
RETVAL="$?"
rm -f "$TEMPFILE"
exit "$RETVAL"
wilbourne
Re: Automatically import ALL AD users in version 3.0.2.3
Post by wilbourne »
You can find the MSQL DB / user and password to used in the EFA-Config file locate in /etc/.
And you can put the script into /usr/local/bin
and add a line into crontab or cron.daily to lauch the script.
dsheetz
Post by dsheetz »
I actually put the script in the cron daily folder (/etc/cron.daily)
I used the username: MAILWATCH
and the "MAILWATCHSQLPWD" password found in (/etc/EFA-Config)
still not populating users.
I moved the script and setup as you suggested and now i GET AN ERROR:
Output from command /usr/local/bin/mailwatch_ldap_sync.sh ..
/bin/sh: /usr/local/bin/mailwatch_ldap_sync.sh: Permission denied
Any suggestions? I am so close here...
dsheetz
Post by dsheetz »
has anyone made importing users automatically work in version 3.0.2.3? I am at a loss
:oops: :( :? :cry:
Did you
sudo chmod +x /usr/local/bin/mailwatch_ldap_sync.sh
dsheetz
Post by dsheetz »
just triied that and ran the script I get this now:
Could not parse LDAP URI(s)=192.168.111.32:389 (3)
/usr/local/bin/mailwatch_ldap_sync.sh: line 144: (&
(objectClass=user)
(proxyAddresses=*)
): command not found
/usr/local/bin/mailwatch_ldap_sync.sh: line 145: proxyAddresses: command not found
ERROR 1045 (28000): Access denied for user 'root'@'localhost' (using password: NO)
/usr/local/bin/mailwatch_ldap_sync.sh: line 242: --port=3306: command not found
/usr/local/bin/mailwatch_ldap_sync.sh: line 243: --user=mailwatch: command not found
<redacted sensitive data>
/usr/local/bin/mailwatch_ldap_sync.sh: line 245: --skip-column-names: command not found
/usr/local/bin/mailwatch_ldap_sync.sh: line 273: /tmp/tmp.ri8jB4m7CO: No such file or director
Looks like a typo in the script.
Can you post the code you have, minus sensitive data (such as the password)?
dsheetz
Post by dsheetz »
#!/bin/bash
# Version: 1.1
# CHANGES
# Version 1.1
# Version 1.0
# - Initial Release
# Configuration #
LDAP_USER=" service_account@mydomain.org"
LDAP_PASS="mypassword"
MYSQL_PORT="3306"
MYSQL_PASS="secretpassword"
(objectClass=user)
(proxyAddresses=*)
"proxyAddresses" |
else
fi
else
fi
done
done
unset DN RESULT
else
fi
fi
done
RETVAL="$?"
rm -f "$TEMPFILE"
exit "$RETVAL"
That script is really old :hand: don't use it. The mailwatch tables don't even look like this any more and have evolved since then.
Although a couple other scripts are out on the forums, I don't recommend them.
I think we need to make a script that is compatible with the newer versions of MailWatch.
I'm going to ponder this for a bit and see how much effort this will take...
dsheetz
Post by dsheetz »
SO I was curious if you cant create a script soon to import all users, is there a manual way to create all users from a csv file? Would I need their passwords?
PS thanks for all your hard work!
dsheetz
Post by dsheetz »
shawniverson wrote: 06 Jul 2017 21:50 That script is really old :hand: don't use it. The mailwatch tables don't even look like this any more and have evolved since then.
Any word on this yet? My boss is hoping you can make something happen, he has faith in you! :pray: :clap:
I should have some time this weekend to work on this ;)
mkamal
Post by mkamal »
I had Working Copy of this script i had modify in the ldapsearch syntax and modify in script to get user email kindly find the attached script
i had test it with version 3.0.1.8 and 3.0.2.3 and against AD 2008 - 2008 R2 -2012 R2 and it work fine
Only Need to change the Ldap Search variable and Change Word Changepass With User password in Whole Script
#!/bin/bash
# Version:                1.1
# CHANGES
# Version 1.1
# Version 1.0
# - Initial Release
# Configuration #
LDAP_URI="server.domain.com"
LDAP_BASE="DC=domain,DC=com"
LDAP_USER="user@domain.com"
LDAP_PASS="changepass"
MYSQL_PORT="3306"
MYSQL_PASS="kD1NVfO333fGje9XDwki8yhLfsjWQAeC9"
DIRNAME="$(dirname "$0")"
LDAP_USERS="$(ldapsearch -LLL -h "$LDAP_URI" -D "$LDAP_USER" -w 'changepass' -x -b "$LDAP_BASE" \
		  (objectClass=user)
		  (mail=*)
		"mail" |
		sed -ne "s/^mail:\(.*\)/\1/p" |
for USER in $LDAP_USERS; do
	RESULT="$(ldapsearch -LLL -h "$LDAP_URI" -D "$LDAP_USER" -w 'changepass' -x -b "$LDAP_BASE" \
		"(mail:=$USER)" \
		"dn" "displayName" "mail" | sed -n '1 {h;$!d}; ${x;s/\n //g;p}; /^ /{H;d}; /^ /!{x;s/\n //g;p}')"
	else
	fi
	else
	fi
	ALIASES="$(echo "$RESULT" | sed -ne "s/^mail:\(.*\)/\1/p")"
	GROUP_ALIASES="$(ldapsearch -LLL -h "$LDAP_URI" -D "$LDAP_USER" -w 'changepass' -x -b "$LDAP_BASE" \
		"(&(objectClass=group)(mail=*)(member=$DN))" \
		"mail" | sed -n '1 {h;$!d}; ${x;s/\n //g;p}; /^ /{H;d}; /^ /!{x;s/\n //g;p}' | sed -ne "s/^mail: [sS][mM][tT][pP]:\(.*\)/\1/p")"
#	for ALIAS in $ALIASES $GROUP_ALIASES; do
#		ALIAS="$(echo "$ALIAS" | sed -e "s/\(.*\)/\L\1/" -e "s/@/\\\@/g")"
#		echo "INSERT INTO user_filters (username, filter, active) VALUES ('$USER', '$ALIAS', 'Y');" >> "$TEMPFILE"
#	done
done
for USER in $MYSQL_USERS; do
	unset DN RESULT
	RESULT="$(ldapsearch -LLL -h "$LDAP_URI" -D "$LDAP_USER" -w 'changepass' -x -b "$LDAP_BASE" "(mail:=$USER)" "dn" | sed -n '1 {h;$!d}; ${x;s/\n //g;p}; /^ /{H;d}; /^ /!{x;s/\n //g;p}')"
	else
	fi
	fi
done
RETVAL="$?"
rm -f "$TEMPFILE"
exit "$RETVAL"
dsheetz
Post by dsheetz »
sorry but I still have 2 dumb questions:
1. what folder should this be copied to?
( I am using /usr/bin/mailwatch_ldap_sync.sh )
2. what credentials should I run this under? I set it to run as a cron job using root but got an error access denied...
error: (/bin/sh: /usr/bin/mailwatch_ldap_sync.sh: Permission denied)
Here's an official script for eFa v3.
https://raw.githubusercontent.com/E-F-A ... D-Sync.php
What it does do:
Uses existing MailWatch LDAP configuration
Creates new accounts/aliases
Properly sanitizes and validates emails from AD/LDAP before importing into MailWatch
What it does not do yet:
Delete old accounts
Update existing aliases
Limitations (PHP 5.3.x)
No LDAP paging support, requires alphabet walk workaround
Very large LDAP DBs with >1000 users in same letter of alphabet will get truncated
These limitations won't apply with eFa v4 since it will use a much newer PHP library.
DrScarpetta
Post by DrScarpetta »
I ran this on a fresh install of 3.0.2.6 and received a lot of
PHP Notice: Undefined index: REMOTE_ADDR in /var/www/html/mailscanner/functions.php on line 3809
errors.
Any idea?
