[EFA] Good you are root
[EFA] Starting update to EFA-3.0.2.3
Setting up Update Process
Determining fastest mirrors
* EFA: dl.efa-project.org
* base: mirror.tobias-wollmann.com
* epel: ftp.nluug.nl
* extras: mirror.netcologne.de
* mariadb: ftp.nluug.nl
* updates: mirror1.hs-esslingen.de
No Packages marked for Update
--2017-05-29 07:27:55-- http://dl.efa-project.org/update/EFA-Update-3.0.2.2-3.0.2.3.tar.gz
Resolving dl.efa-project.org... 188.165.135.228, 2001:41d0:2:524b::228
Connecting to dl.efa-project.org|188.165.135.228|:80... connected.
Length: 5173550 (4.9M) [application/octet-stream]
Saving to: “/tmp/EFA-Staging/EFA-Update-3.0.2.2-3.0.2.3.tar.gz”
0K .......... .......... .......... .......... .......... 0% 2.03M 2s
5050K .. 100% 4377G=0.4s
2017-05-29 07:27:55 (13.9 MB/s) - “/tmp/EFA-Staging/EFA-Update-3.0.2.2-3.0.2.3.tar.gz” saved [5173550/5173550]
--2017-05-29 07:27:55-- http://dl.efa-project.org/update/EFA-Update-3.0.2.2-3.0.2.3.tar.gz.md5
Length: 68 [application/octet-stream]
Saving to: “/tmp/EFA-Staging/EFA-Update-3.0.2.2-3.0.2.3.tar.gz.md5”
0K 100% 10.7M=0s
2017-05-29 07:27:56 (10.7 MB/s) - “/tmp/EFA-Staging/EFA-Update-3.0.2.2-3.0.2.3.tar.gz.md5” saved [68/68]
EFA-Version-Upgrade
Files/
Files/MailWatch-develop-GIT-2833716.zip
Scripts/
Scripts/EFA-Configure
Scripts/lib-EFA-Configure/
Scripts/lib-EFA-Configure/func_ipsettings
Scripts/lib-EFA-Configure/func_tunables_children
Scripts/lib-EFA-Configure/func_asknonspam
Scripts/lib-EFA-Configure/func_askmalwarepatrol
Scripts/lib-EFA-Configure/func_peruser
Scripts/lib-EFA-Configure/func_sethostname
Scripts/lib-EFA-Configure/func_askmaxsizemailwatch
Scripts/lib-EFA-Configure/libraries-filelist.txt
Scripts/lib-EFA-Configure/func_autoupdates
Scripts/lib-EFA-Configure/func_systemrestore
Scripts/lib-EFA-Configure/func_virussettings
Scripts/lib-EFA-Configure/func_tunables_procdb
Scripts/lib-EFA-Configure/func_askspam
Scripts/lib-EFA-Configure/func_askrecursion
Scripts/lib-EFA-Configure/func_mailwatchsettings
Scripts/lib-EFA-Configure/func_spamsettings
Scripts/lib-EFA-Configure/func_mailsettings
Scripts/lib-EFA-Configure/func_asksigrules
Scripts/lib-EFA-Configure/func_maintenance
Scripts/lib-EFA-Configure/func_trustednetworks
Scripts/lib-EFA-Configure/func_recovermysql
Scripts/lib-EFA-Configure/func_askhighspammailwatch
Scripts/lib-EFA-Configure/func_retention
Scripts/lib-EFA-Configure/func_apachesettings
Scripts/lib-EFA-Configure/func_greylisting
Scripts/lib-EFA-Configure/func_resetadmin
Scripts/lib-EFA-Configure/func_getipsettings
Scripts/lib-EFA-Configure/func_ipv6settings
Scripts/lib-EFA-Configure/func_askcleandeliver
Scripts/lib-EFA-Configure/func_setipsettings
Starting update to E.F.A. 3.0.2.3
Beginning System Backup at 05302017 094756
Backup Completed at 05302017 094803
Cleaning repos: EFA base epel extras mariadb updates
Cleaning up Everything
* base: centos.intergenia.de
* epel: epel.mirror.wearetriple.com
* mariadb: mirror.netcologne.de
* updates: centos.intergenia.de
Resolving Dependencies
There are unfinished transactions remaining. You might consider running yum-complete-transaction first to finish them.
--> Running transaction check
---> Package ghostscript.x86_64 0:8.70-21.el6_8.1 will be updated
---> Package ghostscript.x86_64 0:8.70-23.el6 will be updated
---> Package ghostscript.x86_64 0:8.70-23.el6_9.2 will be an update
---> Package jasper-libs.x86_64 0:1.900.1-16.el6_6.3 will be updated
---> Package jasper-libs.x86_64 0:1.900.1-21.el6_9 will be an update
---> Package mod_security.x86_64 0:2.7.3-3.el6 will be updated
---> Package mod_security.x86_64 0:2.7.3-5.el6 will be an update
Dependencies Resolved
Package Arch Version Repository Size
Updating:
ghostscript x86_64 8.70-23.el6_9.2 updates 4.4 M
jasper-libs x86_64 1.900.1-21.el6_9 updates 138 k
mod_security x86_64 2.7.3-5.el6 epel 168 k
Transaction Summary
Upgrade 3 Package(s)
Total download size: 4.7 M
Downloading Packages:
Total 9.7 MB/s | 4.7 MB 00:00
Running rpm_check_debug
Running Transaction Test
Transaction Test Succeeded
Running Transaction
Updating : jasper-libs-1.900.1-21.el6_9.x86_64 1/7
Updating : ghostscript-8.70-23.el6_9.2.x86_64 2/7
Updating : mod_security-2.7.3-5.el6.x86_64 3/7
Cleanup : ghostscript.x86_64 4/7
Cleanup : ghostscript.x86_64 5/7
Cleanup : jasper-libs-1.900.1-16.el6_6.3.x86_64 6/7
Cleanup : mod_security-2.7.3-3.el6.x86_64 7/7
Verifying : mod_security-2.7.3-5.el6.x86_64 1/7
Verifying : jasper-libs-1.900.1-21.el6_9.x86_64 2/7
Verifying : ghostscript-8.70-23.el6_9.2.x86_64 3/7
Verifying : ghostscript-8.70-23.el6.x86_64 4/7
Verifying : mod_security-2.7.3-3.el6.x86_64 5/7
Verifying : ghostscript-8.70-21.el6_8.1.x86_64 6/7
Verifying : jasper-libs-1.900.1-16.el6_6.3.x86_64 7/7
Updated:
ghostscript.x86_64 0:8.70-23.el6_9.2 jasper-libs.x86_64 0:1.900.1-21.el6_9
Complete!
Starting installation of new mailwatch version
Stopping httpd: [ OK ]
MailScanner stopped
Archive: /tmp/EFA-Staging/Files/MailWatch-develop-GIT-2833716.zip
creat:/usr/src/EFA/MailWatch-develop/.github/
infl:/usr/src/EFA/MailWatch-develop/.github/ISSUE_TEMPLATE.md
infl:/usr/src/EFA/MailWatch-develop/.gitignore
infl:/usr/src/EFA/MailWatch-develop/.styleci.yml
infl:/usr/src/EFA/MailWatch-develop/CHANGELOG.md
infl:/usr/src/EFA/MailWatch-develop/CONTRIBUTING.md
infl:/usr/src/EFA/MailWatch-develop/create.sql
infl:/usr/src/EFA/MailWatch-develop/fix_quarantine_permissions
infl:/usr/src/EFA/MailWatch-develop/INSTALL
infl:/usr/src/EFA/MailWatch-develop/LICENSE.md
creat:/u/s/E/MW-dev/ms/
infl:/u/s/E/MW-dev/ms/auto-release.php
infl:/u/s/E/MW-dev/ms/bayes_info.php
infl:/u/s/E/MW-dev/ms/checklogin.php
infl:/u/s/E/MW-dev/ms/clamav.awk
infl:/u/s/E/MW-dev/ms/clamav_status.php
infl:/u/s/E/MW-dev/ms/conf.php.example
infl:/u/s/E/MW-dev/ms/database.php
infl:/u/s/E/MW-dev/ms/detail.php
infl:/u/s/E/MW-dev/ms/do_message_ops.php
infl:/u/s/E/MW-dev/ms/docs.php
creat:/u/s/E/MW-dev/ms/docs/
infl:/u/s/E/MW-dev/ms/docs/howto_configure_outlook.html
infl:/u/s/E/MW-dev/ms/docs/howto_train_spamassassin.html
extrg:/u/s/E/MW-dev/ms/docs/index.html
infl:/u/s/E/MW-dev/ms/favicon.ico
infl:/u/s/E/MW-dev/ms/filter.inc.php
infl:/u/s/E/MW-dev/ms/f-prot.awk
infl:/u/s/E/MW-dev/ms/f-prot_status.php
infl:/u/s/E/MW-dev/ms/f-secure.awk
infl:/u/s/E/MW-dev/ms/f-secure_status.php
infl:/u/s/E/MW-dev/ms/functions.php
infl:/u/s/E/MW-dev/ms/geoip_update.php
creat:/u/s/E/MW-dev/ms/images/
creat:/u/s/E/MW-dev/ms/images/cache/
infl:/u/s/E/MW-dev/ms/images/cache/.gitignore
extrg:/u/s/E/MW-dev/ms/images/favicon.png
extrg:/u/s/E/MW-dev/ms/images/index.html
infl:/u/s/E/MW-dev/ms/images/info-circle.png
infl:/u/s/E/MW-dev/ms/images/info-circle-hover.png
infl:/u/s/E/MW-dev/ms/images/mailwatch-logo.png
infl:/u/s/E/MW-dev/ms/index.php
creat:/u/s/E/MW-dev/ms/languages/
infl:/u/s/E/MW-dev/ms/languages/de.php
infl:/u/s/E/MW-dev/ms/languages/en.php
infl:/u/s/E/MW-dev/ms/languages/fr.php
extrg:/u/s/E/MW-dev/ms/languages/index.html
infl:/u/s/E/MW-dev/ms/languages/it.php
infl:/u/s/E/MW-dev/ms/languages/nl.php
infl:/u/s/E/MW-dev/ms/languages/pt_br.php
creat:/u/s/E/MW-dev/ms/lib/
creat:/u/s/E/MW-dev/ms/lib/Chart.js/
infl:/u/s/E/MW-dev/ms/lib/Chart.js/Chart.js
infl:/u/s/E/MW-dev/ms/lib/Chart.js/Chart.min.js
extrg:/u/s/E/MW-dev/ms/lib/Chart.js/index.html
infl:/u/s/E/MW-dev/ms/lib/Chart.js/LICENSE.md
infl:/u/s/E/MW-dev/ms/lib/geoip.inc
infl:/u/s/E/MW-dev/ms/lib/hash_equals.php
creat:/u/s/E/MW-dev/ms/lib/htmlpurifier/
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/HTMLPurifier.standalone.php
creat:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/
creat:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/
creat:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/
creat:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/Builder/
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/Builder/ConfigSchema.php
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/Builder/Xml.php
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/Exception.php
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/Interchange.php
creat:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/Interchange/
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/Interchange/Directive.php
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/Interchange/Id.php
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/InterchangeBuilder.php
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema.ser
creat:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Attr.AllowedClasses.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Attr.AllowedFrameTargets.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Attr.AllowedRel.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Attr.AllowedRev.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Attr.ClassUseCDATA.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Attr.DefaultImageAlt.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Attr.DefaultInvalidImage.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Attr.DefaultInvalidImageAlt.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Attr.DefaultTextDir.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Attr.EnableID.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Attr.ForbiddenClasses.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Attr.ID.HTML5.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Attr.IDBlacklist.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Attr.IDBlacklistRegexp.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Attr.IDPrefix.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Attr.IDPrefixLocal.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/AutoFormat.AutoParagraph.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/AutoFormat.Custom.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/AutoFormat.DisplayLinkURI.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/AutoFormat.Linkify.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/AutoFormat.PurifierLinkify.DocURL.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/AutoFormat.PurifierLinkify.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/AutoFormat.RemoveEmpty.Predicate.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/AutoFormat.RemoveEmpty.RemoveNbsp.Exceptions.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/AutoFormat.RemoveEmpty.RemoveNbsp.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/AutoFormat.RemoveEmpty.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/AutoFormat.RemoveSpansWithoutAttributes.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Cache.DefinitionImpl.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Cache.SerializerPath.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Cache.SerializerPermissions.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Core.AggressivelyFixLt.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Core.AllowHostnameUnderscore.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Core.CollectErrors.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Core.ColorKeywords.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Core.ConvertDocumentToFragment.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Core.DirectLexLineNumberSyncInterval.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Core.DisableExcludes.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Core.EnableIDNA.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Core.Encoding.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Core.EscapeInvalidChildren.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Core.EscapeInvalidTags.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Core.EscapeNonASCIICharacters.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Core.HiddenElements.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Core.Language.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Core.LexerImpl.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Core.MaintainLineNumbers.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Core.NormalizeNewlines.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Core.RemoveInvalidImg.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Core.RemoveProcessingInstructions.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Core.RemoveScriptContents.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/CSS.AllowDuplicates.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/CSS.AllowedFonts.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/CSS.AllowedProperties.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/CSS.AllowImportant.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/CSS.AllowTricky.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/CSS.DefinitionRev.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/CSS.ForbiddenProperties.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/CSS.MaxImgLength.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/CSS.Proprietary.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/CSS.Trusted.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Filter.Custom.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Filter.ExtractStyleBlocks.Escaping.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Filter.ExtractStyleBlocks.Scope.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Filter.ExtractStyleBlocks.TidyImpl.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Filter.ExtractStyleBlocks.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Filter.YouTube.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.Allowed.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.AllowedAttributes.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.AllowedComments.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.AllowedCommentsRegexp.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.AllowedElements.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.AllowedModules.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.Attr.Name.UseCDATA.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.BlockWrapper.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.CoreModules.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.CustomDoctype.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.DefinitionID.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.DefinitionRev.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.Doctype.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.FlashAllowFullScreen.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.ForbiddenAttributes.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.ForbiddenElements.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.MaxImgLength.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.Nofollow.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.Parent.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.Proprietary.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.SafeEmbed.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.SafeIframe.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.SafeObject.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.SafeScripting.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.Strict.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.TargetBlank.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.TargetNoreferrer.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.TidyAdd.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.TidyLevel.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.TidyRemove.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.Trusted.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.XHTML.txt
extrg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/info.ini
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Output.CommentScriptContents.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Output.FixInnerHTML.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Output.FlashCompat.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Output.Newline.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Output.SortAttr.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Output.TidyFormat.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Test.ForceNoIconv.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/URI.AllowedSchemes.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/URI.Base.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/URI.DefaultScheme.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/URI.DefinitionID.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/URI.DefinitionRev.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/URI.Disable.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/URI.DisableExternal.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/URI.DisableExternalResources.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/URI.DisableResources.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/URI.Host.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/URI.HostBlacklist.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/URI.MakeAbsolute.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/URI.Munge.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/URI.MungeResources.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/URI.MungeSecretKey.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/URI.OverrideAllowedSchemes.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/URI.SafeIframeRegexp.txt
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/Validator.php
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/ValidatorAtom.php
creat:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/DefinitionCache/
creat:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/DefinitionCache/Serializer/
creat:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/DefinitionCache/Serializer/HTML/
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/DefinitionCache/Serializer/HTML/4.8.0,b6889960956c877d241a7e8f87e613efc7a3611d,1.ser
creat:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/EntityLookup/
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/EntityLookup/entities.ser
creat:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/Filter/
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/Filter/ExtractStyleBlocks.php
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/Filter/YouTube.php
creat:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/Language/
creat:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/Language/classes/
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/Language/classes/en-x-test.php
creat:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/Language/messages/
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/Language/messages/en.php
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/Language/messages/en-x-test.php
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/Language/messages/en-x-testmini.php
creat:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/Lexer/
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/Lexer/PH5P.php
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/Printer.php
creat:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/Printer/
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/Printer/ConfigForm.css
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/Printer/ConfigForm.js
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/Printer/ConfigForm.php
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/Printer/CSSDefinition.php
infl:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/Printer/HTMLDefinition.php
extrg:/u/s/E/MW-dev/ms/lib/index.html
infl:/u/s/E/MW-dev/ms/lib/IPSet.php
creat:/u/s/E/MW-dev/ms/lib/jpgraph/
creat:/u/s/E/MW-dev/ms/lib/jpgraph/src/
creat:/u/s/E/MW-dev/ms/lib/jpgraph/src/barcode/
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/barcode/mkbarcode.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/flag_mapping
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/flags.dat
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/flags_thumb100x100.dat
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/flags_thumb35x35.dat
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/flags_thumb60x60.dat
creat:/u/s/E/MW-dev/ms/lib/jpgraph/src/fonts/
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/fonts/DejaVuSans.ttf
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/fonts/DejaVuSans-Bold.ttf
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/fonts/DejaVuSans-BoldOblique.ttf
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/fonts/DejaVuSans-Oblique.ttf
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/fonts/FF_FONT0.gdf
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/fonts/FF_FONT0-Bold.gdf
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/fonts/FF_FONT1.gdf
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/fonts/FF_FONT1-Bold.gdf
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/fonts/FF_FONT2.gdf
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/fonts/FF_FONT2-Bold.gdf
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/gd_image.inc.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/imageSmoothArc.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/imgdata_balls.inc.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/imgdata_bevels.inc.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/imgdata_diamonds.inc.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/imgdata_pushpins.inc.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/imgdata_squares.inc.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/imgdata_stars.inc.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpg-config.inc.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpg-config.inc.php.orig
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_antispam.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_antispam-digits.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_bar.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_canvas.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_canvtools.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_contour.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_date.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_errhandler.inc.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_error.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_flags.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_gantt.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_gb2312.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_gradient.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_iconplot.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_imgtrans.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_led.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_legend.inc.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_line.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_log.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_meshinterpolate.inc.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_mgraph.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_pie.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_pie3d.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_plotband.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_plotline.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_plotmark.inc.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_polar.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_radar.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_regstat.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_rgb.inc.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_scatter.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_stock.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_table.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_text.inc.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_theme.inc.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_ttf.inc.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_utils.inc.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_windrose.php
creat:/u/s/E/MW-dev/ms/lib/jpgraph/src/lang/
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/lang/de.inc.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/lang/en.inc.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/lang/prod.inc.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/README
creat:/u/s/E/MW-dev/ms/lib/jpgraph/src/themes/
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/themes/AquaTheme.class.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/themes/GreenTheme.class.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/themes/OceanTheme.class.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/themes/OrangeTheme.class.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/themes/PastelTheme.class.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/themes/RoseTheme.class.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/themes/SoftyTheme.class.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/themes/UniversalTheme.class.php
infl:/u/s/E/MW-dev/ms/lib/jpgraph/src/themes/VividTheme.class.php
extrg:/u/s/E/MW-dev/ms/lib/jpgraph/VERSION
infl:/u/s/E/MW-dev/ms/lib/password.php
creat:/u/s/E/MW-dev/ms/lib/pear/
infl:/u/s/E/MW-dev/ms/lib/pear/LICENSE
infl:/u/s/E/MW-dev/ms/lib/pear/Mail.php
creat:/u/s/E/MW-dev/ms/lib/pear/Mail/
infl:/u/s/E/MW-dev/ms/lib/pear/Mail/mail.php
infl:/u/s/E/MW-dev/ms/lib/pear/Mail/mime.php
infl:/u/s/E/MW-dev/ms/lib/pear/Mail/mimeDecode.php
infl:/u/s/E/MW-dev/ms/lib/pear/Mail/mimePart.php
infl:/u/s/E/MW-dev/ms/lib/pear/Mail/mock.php
infl:/u/s/E/MW-dev/ms/lib/pear/Mail/null.php
infl:/u/s/E/MW-dev/ms/lib/pear/Mail/RFC822.php
infl:/u/s/E/MW-dev/ms/lib/pear/Mail/sendmail.php
infl:/u/s/E/MW-dev/ms/lib/pear/Mail/smtp.php
infl:/u/s/E/MW-dev/ms/lib/pear/Mail/smtpmx.php
creat:/u/s/E/MW-dev/ms/lib/pear/Net/
infl:/u/s/E/MW-dev/ms/lib/pear/Net/SMTP.php
infl:/u/s/E/MW-dev/ms/lib/pear/Net/Socket.php
creat:/u/s/E/MW-dev/ms/lib/pear/OS/
infl:/u/s/E/MW-dev/ms/lib/pear/OS/Guess.php
infl:/u/s/E/MW-dev/ms/lib/pear/Pager.php
creat:/u/s/E/MW-dev/ms/lib/pear/Pager/
infl:/u/s/E/MW-dev/ms/lib/pear/Pager/Common.php
infl:/u/s/E/MW-dev/ms/lib/pear/Pager/HtmlWidgets.php
infl:/u/s/E/MW-dev/ms/lib/pear/Pager/Jumping.php
infl:/u/s/E/MW-dev/ms/lib/pear/Pager/Pager.php
infl:/u/s/E/MW-dev/ms/lib/pear/Pager/Sliding.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR.php
creat:/u/s/E/MW-dev/ms/lib/pear/PEAR/
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Autoloader.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Builder.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/ChannelFile.php
creat:/u/s/E/MW-dev/ms/lib/pear/PEAR/ChannelFile/
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/ChannelFile/Parser.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Command.php
creat:/u/s/E/MW-dev/ms/lib/pear/PEAR/Command/
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Command/Auth.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Command/Auth.xml
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Command/Build.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Command/Build.xml
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Command/Channels.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Command/Channels.xml
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Command/Common.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Command/Config.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Command/Config.xml
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Command/Install.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Command/Install.xml
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Command/Mirror.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Command/Mirror.xml
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Command/Package.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Command/Package.xml
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Command/Pickle.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Command/Pickle.xml
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Command/Registry.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Command/Registry.xml
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Command/Remote.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Command/Remote.xml
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Command/Test.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Command/Test.xml
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Common.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Config.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Dependency2.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/DependencyDB.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Downloader.php
creat:/u/s/E/MW-dev/ms/lib/pear/PEAR/Downloader/
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Downloader/Package.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/ErrorStack.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Exception.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Frontend.php
creat:/u/s/E/MW-dev/ms/lib/pear/PEAR/Frontend/
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Frontend/CLI.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Installer.php
creat:/u/s/E/MW-dev/ms/lib/pear/PEAR/Installer/
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Installer/Role.php
creat:/u/s/E/MW-dev/ms/lib/pear/PEAR/Installer/Role/
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Installer/Role/Cfg.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Installer/Role/Cfg.xml
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Installer/Role/Common.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Installer/Role/Data.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Installer/Role/Data.xml
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Installer/Role/Doc.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Installer/Role/Doc.xml
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Installer/Role/Ext.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Installer/Role/Ext.xml
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Installer/Role/Man.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Installer/Role/Man.xml
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Installer/Role/Php.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Installer/Role/Php.xml
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Installer/Role/Script.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Installer/Role/Script.xml
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Installer/Role/Src.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Installer/Role/Src.xml
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Installer/Role/Test.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Installer/Role/Test.xml
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Installer/Role/Www.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Installer/Role/Www.xml
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/PackageFile.php
creat:/u/s/E/MW-dev/ms/lib/pear/PEAR/PackageFile/
creat:/u/s/E/MW-dev/ms/lib/pear/PEAR/PackageFile/Generator/
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/PackageFile/Generator/v1.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/PackageFile/Generator/v2.php
creat:/u/s/E/MW-dev/ms/lib/pear/PEAR/PackageFile/Parser/
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/PackageFile/Parser/v1.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/PackageFile/Parser/v2.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/PackageFile/v1.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/PackageFile/v2.php
creat:/u/s/E/MW-dev/ms/lib/pear/PEAR/PackageFile/v2/
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/PackageFile/v2/rw.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/PackageFile/v2/Validator.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Packager.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Registry.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/REST.php
creat:/u/s/E/MW-dev/ms/lib/pear/PEAR/REST/
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/REST/10.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/REST/11.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/REST/13.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/RunTest.php
creat:/u/s/E/MW-dev/ms/lib/pear/PEAR/Task/
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Task/Common.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Task/Postinstallscript.php
creat:/u/s/E/MW-dev/ms/lib/pear/PEAR/Task/Postinstallscript/
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Task/Postinstallscript/rw.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Task/Replace.php
creat:/u/s/E/MW-dev/ms/lib/pear/PEAR/Task/Replace/
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Task/Replace/rw.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Task/Unixeol.php
creat:/u/s/E/MW-dev/ms/lib/pear/PEAR/Task/Unixeol/
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Task/Unixeol/rw.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Task/Windowseol.php
creat:/u/s/E/MW-dev/ms/lib/pear/PEAR/Task/Windowseol/
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Task/Windowseol/rw.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Validate.php
creat:/u/s/E/MW-dev/ms/lib/pear/PEAR/Validator/
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/Validator/PECL.php
infl:/u/s/E/MW-dev/ms/lib/pear/PEAR/XMLParser.php
infl:/u/s/E/MW-dev/ms/lib/pear/System.php
creat:/u/s/E/MW-dev/ms/lib/request/
infl:/u/s/E/MW-dev/ms/lib/request/Requests.php
creat:/u/s/E/MW-dev/ms/lib/request/Requests/
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Auth.php
creat:/u/s/E/MW-dev/ms/lib/request/Requests/Auth/
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Auth/Basic.php
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Cookie.php
creat:/u/s/E/MW-dev/ms/lib/request/Requests/Cookie/
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Cookie/Jar.php
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Exception.php
creat:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP.php
creat:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/400.php
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/401.php
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/402.php
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/403.php
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/404.php
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/405.php
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/406.php
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/407.php
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/408.php
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/409.php
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/410.php
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/411.php
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/412.php
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/413.php
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/414.php
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/415.php
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/416.php
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/417.php
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/418.php
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/428.php
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/429.php
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/431.php
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/500.php
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/501.php
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/502.php
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/503.php
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/504.php
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/505.php
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/511.php
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/Unknown.php
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Hooker.php
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Hooks.php
infl:/u/s/E/MW-dev/ms/lib/request/Requests/IDNAEncoder.php
infl:/u/s/E/MW-dev/ms/lib/request/Requests/IPv6.php
infl:/u/s/E/MW-dev/ms/lib/request/Requests/IRI.php
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Proxy.php
creat:/u/s/E/MW-dev/ms/lib/request/Requests/Proxy/
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Proxy/HTTP.php
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Proxy/SOCKS5.php
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Response.php
creat:/u/s/E/MW-dev/ms/lib/request/Requests/Response/
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Response/Headers.php
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Session.php
infl:/u/s/E/MW-dev/ms/lib/request/Requests/SSL.php
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Transport.php
creat:/u/s/E/MW-dev/ms/lib/request/Requests/Transport/
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Transport/cacert.pem
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Transport/cURL.php
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Transport/fsockopen.php
creat:/u/s/E/MW-dev/ms/lib/request/Requests/Utility/
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Utility/CaseInsensitiveDictionary.php
infl:/u/s/E/MW-dev/ms/lib/request/Requests/Utility/FilteredIterator.php
creat:/u/s/E/MW-dev/ms/lib/xmlrpc/
infl:/u/s/E/MW-dev/ms/lib/xmlrpc/xmlrpc.inc
infl:/u/s/E/MW-dev/ms/lib/xmlrpc/xmlrpc_wrappers.inc
infl:/u/s/E/MW-dev/ms/lib/xmlrpc/xmlrpcs.inc
infl:/u/s/E/MW-dev/ms/lists.php
infl:/u/s/E/MW-dev/ms/login.function.php
infl:/u/s/E/MW-dev/ms/login.php
infl:/u/s/E/MW-dev/ms/logout.php
infl:/u/s/E/MW-dev/ms/mailq.php
infl:/u/s/E/MW-dev/ms/mcafee.awk
infl:/u/s/E/MW-dev/ms/mcafee_status.php
infl:/u/s/E/MW-dev/ms/mcp_rules_update.php
infl:/u/s/E/MW-dev/ms/ms_lint.php
infl:/u/s/E/MW-dev/ms/msconfig.php
infl:/u/s/E/MW-dev/ms/msre_edit.php
infl:/u/s/E/MW-dev/ms/msre_index.php
infl:/u/s/E/MW-dev/ms/msre_table_functions.php
infl:/u/s/E/MW-dev/ms/msrule.php
infl:/u/s/E/MW-dev/ms/mtalogprocessor.inc.php
infl:/u/s/E/MW-dev/ms/mysql_status.php
infl:/u/s/E/MW-dev/ms/other.php
infl:/u/s/E/MW-dev/ms/password_reset.php
infl:/u/s/E/MW-dev/ms/postfix.inc.php
infl:/u/s/E/MW-dev/ms/postfixmailq.php
infl:/u/s/E/MW-dev/ms/quarantine.php
infl:/u/s/E/MW-dev/ms/quarantine_action.php
infl:/u/s/E/MW-dev/ms/quarantine_report.inc.php
infl:/u/s/E/MW-dev/ms/rep_audit_log.php
infl:/u/s/E/MW-dev/ms/rep_mcp_rule_hits.php
infl:/u/s/E/MW-dev/ms/rep_mcp_score_dist.php
infl:/u/s/E/MW-dev/ms/rep_message_listing.php
infl:/u/s/E/MW-dev/ms/rep_message_ops.php
infl:/u/s/E/MW-dev/ms/rep_mrtg_style.php
infl:/u/s/E/MW-dev/ms/rep_sa_rule_hits.php
infl:/u/s/E/MW-dev/ms/rep_sa_score_dist.php
infl:/u/s/E/MW-dev/ms/rep_top_mail_relays.php
infl:/u/s/E/MW-dev/ms/rep_top_recipient_domains_by_quantity.php
infl:/u/s/E/MW-dev/ms/rep_top_recipient_domains_by_volume.php
infl:/u/s/E/MW-dev/ms/rep_top_recipients_by_quantity.php
infl:/u/s/E/MW-dev/ms/rep_top_recipients_by_volume.php
infl:/u/s/E/MW-dev/ms/rep_top_sender_domains_by_quantity.php
infl:/u/s/E/MW-dev/ms/rep_top_sender_domains_by_volume.php
infl:/u/s/E/MW-dev/ms/rep_top_senders_by_quantity.php
infl:/u/s/E/MW-dev/ms/rep_top_senders_by_volume.php
infl:/u/s/E/MW-dev/ms/rep_top_viruses.php
infl:/u/s/E/MW-dev/ms/rep_total_mail_by_date.php
infl:/u/s/E/MW-dev/ms/rep_viruses.php
infl:/u/s/E/MW-dev/ms/reports.php
extrg:/u/s/E/MW-dev/ms/robots.txt
infl:/u/s/E/MW-dev/ms/rpcserver.php
infl:/u/s/E/MW-dev/ms/sa_lint.php
infl:/u/s/E/MW-dev/ms/sa_rules_update.php
infl:/u/s/E/MW-dev/ms/sf_version.php
infl:/u/s/E/MW-dev/ms/sophos.awk
infl:/u/s/E/MW-dev/ms/sophos_status.php
infl:/u/s/E/MW-dev/ms/status.php
infl:/u/s/E/MW-dev/ms/style.css
infl:/u/s/E/MW-dev/ms/syslog_parser.inc.php
creat:/u/s/E/MW-dev/ms/temp/
infl:/u/s/E/MW-dev/ms/temp/.gitignore
extrg:/u/s/E/MW-dev/ms/temp/index.html
infl:/u/s/E/MW-dev/ms/user_manager.php
infl:/u/s/E/MW-dev/ms/viewmail.php
infl:/u/s/E/MW-dev/ms/viewpart.php
creat:/usr/src/EFA/MailWatch-develop/MailScanner_perl_scripts/
infl:/usr/src/EFA/MailWatch-develop/MailScanner_perl_scripts/INSTALL
infl:/usr/src/EFA/MailWatch-develop/MailScanner_perl_scripts/MailWatch.pm
infl:/usr/src/EFA/MailWatch-develop/MailScanner_perl_scripts/MailWatchConf.pm
infl:/usr/src/EFA/MailWatch-develop/MailScanner_perl_scripts/SQLBlackWhiteList.pm
infl:/usr/src/EFA/MailWatch-develop/MailScanner_perl_scripts/SQLSpamSettings.pm
infl:/usr/src/EFA/MailWatch-develop/README.md
infl:/usr/src/EFA/MailWatch-develop/Remote_DB.txt
infl:/usr/src/EFA/MailWatch-develop/SECURITY
creat:/usr/src/EFA/MailWatch-develop/tools/
creat:/usr/src/EFA/MailWatch-develop/tools/Cron_jobs/
infl:/usr/src/EFA/MailWatch-develop/tools/Cron_jobs/INSTALL
infl:/usr/src/EFA/MailWatch-develop/tools/Cron_jobs/mailwatch
infl:/usr/src/EFA/MailWatch-develop/tools/Cron_jobs/mailwatch_db_clean.php
infl:/usr/src/EFA/MailWatch-develop/tools/Cron_jobs/mailwatch_quarantine_maint.php
infl:/usr/src/EFA/MailWatch-develop/tools/Cron_jobs/mailwatch_quarantine_report.php
creat:/usr/src/EFA/MailWatch-develop/tools/LDAP/
infl:/usr/src/EFA/MailWatch-develop/tools/LDAP/mailwatch_ldap_sync.sh
creat:/usr/src/EFA/MailWatch-develop/tools/MailScanner_config/
infl:/usr/src/EFA/MailWatch-develop/tools/MailScanner_config/00_MailWatch.conf
creat:/usr/src/EFA/MailWatch-develop/tools/MailScanner_rule_editor/
infl:/usr/src/EFA/MailWatch-develop/tools/MailScanner_rule_editor/INSTALL
infl:/usr/src/EFA/MailWatch-develop/tools/MailScanner_rule_editor/msre_reload.crontab
infl:/usr/src/EFA/MailWatch-develop/tools/MailScanner_rule_editor/msre_reload.sh
creat:/usr/src/EFA/MailWatch-develop/tools/Postfix_relay/
infl:/usr/src/EFA/MailWatch-develop/tools/Postfix_relay/INSTALL
infl:/usr/src/EFA/MailWatch-develop/tools/Postfix_relay/mailwatch_mailscanner_relay.php
infl:/usr/src/EFA/MailWatch-develop/tools/Postfix_relay/mailwatch_postfix_relay.php
infl:/usr/src/EFA/MailWatch-develop/tools/Postfix_relay/mailwatch-postfix-relay
creat:/usr/src/EFA/MailWatch-develop/tools/Sendmail_relay/
infl:/usr/src/EFA/MailWatch-develop/tools/Sendmail_relay/INSTALL
infl:/usr/src/EFA/MailWatch-develop/tools/Sendmail_relay/mailwatch_sendmail_relay.php
infl:/usr/src/EFA/MailWatch-develop/tools/Sendmail_relay/mailwatch-sendmail-relay
creat:/usr/src/EFA/MailWatch-develop/tools/Sendmail-Exim_queue/
infl:/usr/src/EFA/MailWatch-develop/tools/Sendmail-Exim_queue/INSTALL
infl:/usr/src/EFA/MailWatch-develop/tools/Sendmail-Exim_queue/mailq.crontab
infl:/usr/src/EFA/MailWatch-develop/tools/Sendmail-Exim_queue/mailwatch_sendmail_queue.php
creat:/usr/src/EFA/MailWatch-develop/tools/sudo/
infl:/usr/src/EFA/MailWatch-develop/tools/sudo/INSTALL
infl:/usr/src/EFA/MailWatch-develop/tools/sudo/mailwatch
infl:/usr/src/EFA/MailWatch-develop/upgrade.php
infl:/usr/src/EFA/MailWatch-develop/UPGRADING
infl:/usr/src/EFA/MailWatch-develop/USER_FILTERS
MailWatch for MailScanner Database Upgrade to 1.2.3-dev
Testing connectivity to the database ................................. OK
Updating database schema:
- Convert database to utf8........................................... ALREADY DONE
- Drop `geoip_country` table......................................... ALREADY DROPPED
- Drop `spamscores` table............................................ ALREADY DROPPED
- Add autorelease table to `mailscanner` database.................... ALREADY EXIST
- Add resetid, resetexpire and lastreset fields in `users` table..... ALREADY EXIST
- Add login_expiry and login_timeout fields in `users` table......... OK
- Fix schema for username field in `audit_log` table................. OK
- Fix schema for id field in `blacklist` table....................... OK
- Fix schema for username field in `users` table..................... OK
- Fix schema for spamscore field in `users` table.................... OK
- Fix schema for highspamscore field in `users` table................ OK
- Fix schema for username field in `user_filters` table.............. OK
- Fix schema for username field in `whitelist` table................. OK
- Fix schema for password field in `users` table..................... OK
- Fix schema for fullname field in `users` table..................... OK
- Fix schema for rule_desc field in `mcp_rules` table................ OK
- Cleanup orphaned user_filters...................................... OK
- Add id field and primary key to `audit_log` table.................. ALREADY DONE
- Add inq_id field and primary key to `inq` table.................... ALREADY DONE
- Add maillog_id field and primary key to `maillog` table............ ALREADY DONE
- Add rblspamreport field to `maillog` table......................... ALREADY DONE
- Add token field to `maillog` table................................. ALREADY DONE
- Check for missing tokens in `maillog` table........................ DONE
0 token generated
- Add mtalog_id field and primary key to `mtalog` table.............. ALREADY DONE
- Add mtalog_id field and primary key to `outq` table................ ALREADY DONE
- Add id field and primary key to `saved_filters` table.............. ALREADY DONE
- Add mtalog_id field and primary key to `user_filters` table........ ALREADY DONE
- Dropping too big index `maillog_from_idx` on table `maillog`....... ALREADY DONE
- Dropping too big index `maillog_to_idx` on table `maillog`......... ALREADY DONE
- Convert database to utf8mb4........................................ ALREADY DONE
- Convert table `audit_log` to utf8mb4............................... ALREADY CONVERTED
- Convert table `autorelease` to utf8mb4............................. ALREADY CONVERTED
- Convert table `blacklist` to utf8mb4............................... ALREADY CONVERTED
- Convert table `inq` to utf8mb4..................................... ALREADY CONVERTED
- Convert table `maillog` to utf8mb4................................. ALREADY CONVERTED
- Convert table `mcp_rules` to utf8mb4............................... ALREADY CONVERTED
- Convert table `mtalog` to utf8mb4.................................. ALREADY CONVERTED
- Convert table `mtalog_ids` to utf8mb4.............................. ALREADY CONVERTED
- Convert table `outq` to utf8mb4.................................... ALREADY CONVERTED
- Convert table `saved_filters` to utf8mb4........................... ALREADY CONVERTED
- Convert table `sa_rules` to utf8mb4................................ ALREADY CONVERTED
- Convert table `users` to utf8mb4................................... ALREADY CONVERTED
- Convert table `user_filters` to utf8mb4............................ ALREADY CONVERTED
- Convert table `whitelist` to utf8mb4............................... ALREADY CONVERTED
- Convert table `audit_log` to InnoDB................................ ALREADY CONVERTED
- Convert table `autorelease` to InnoDB.............................. ALREADY CONVERTED
- Convert table `blacklist` to InnoDB................................ ALREADY CONVERTED
- Convert table `inq` to InnoDB...................................... ALREADY CONVERTED
- Convert table `maillog` to InnoDB.................................. ALREADY CONVERTED
- Convert table `mcp_rules` to InnoDB................................ ALREADY CONVERTED
- Convert table `mtalog` to InnoDB................................... ALREADY CONVERTED
- Convert table `mtalog_ids` to InnoDB............................... ALREADY CONVERTED
- Convert table `outq` to InnoDB..................................... ALREADY CONVERTED
- Convert table `saved_filters` to InnoDB............................ ALREADY CONVERTED
- Convert table `sa_rules` to InnoDB................................. ALREADY CONVERTED
- Convert table `users` to InnoDB.................................... ALREADY CONVERTED
- Convert table `user_filters` to InnoDB............................. ALREADY CONVERTED
- Convert table `whitelist` to InnoDB................................ ALREADY CONVERTED
- Search for missing indexes on table `maillog`...................... DONE
- Adding missing index `subject_idx` on table `maillog`.............. WARNING
Checking MailScanner.conf settings:
- QuarantineWholeMessage ............................................ OK
- QuarantineWholeMessagesAsQueueFiles ............................... OK
- DetailedSpamReport ................................................ OK
- IncludeScoresInSpamAssassinReport ................................. OK
- SpamActions ....................................................... OK
- HighScoringSpamActions ............................................ OK
- AlwaysLookedUpLast ................................................ OK
Checking conf.php configuration entry:
- All mandatory entries are present.................................. OK
- All obsolete entries are already removed........................... OK
- optional RPC_PORT ................................................. WARNING
- optional RPC_SSL .................................................. WARNING
- optional RPC_REMOTE_SERVER ........................................ WARNING
- optional LDAP_BIND_PREFIX ......................................... WARNING
- optional LDAP_BIND_SUFFIX ......................................... WARNING
- optional EXIM_QUEUE_IN ............................................ WARNING
- optional EXIM_QUEUE_OUT ........................................... WARNING
- optional PWD_RESET_FROM_NAME ...................................... WARNING
- optional PWD_RESET_FROM_ADDRESS ................................... WARNING
- optional MAIL_SENDER .............................................. WARNING
- optional SESSION_NAME ............................................. WARNING
- optional USER_SELECTABLE_LANG ..................................... WARNING
- optional MAILWATCH_SMTP_HOSTNAME .................................. WARNING
- optional SESSION_TIMEOUT .......................................... WARNING
*** ERROR/WARNING SUMMARY ***
Table Index: MySQL version unsupported for index `subject_idx` on table `maillog`, upgrade to version >= 50604 (you have version 50505)
conf.php: optional configuration entry "RPC_PORT" is missing, needed if RPC_ONLY mode is enabled
conf.php: optional configuration entry "RPC_SSL" is missing, needed if RPC_ONLY mode is enabled
conf.php: optional configuration entry "RPC_REMOTE_SERVER" is missing, needed to show number of mails in postfix queues on remote server (RPC)
conf.php: optional configuration entry "LDAP_BIND_PREFIX" is missing, needed when using LDAP authentication
conf.php: optional configuration entry "LDAP_BIND_SUFFIX" is missing, needed when using LDAP authentication
conf.php: optional configuration entry "EXIM_QUEUE_IN" is missing, needed only if using Exim as MTA
conf.php: optional configuration entry "EXIM_QUEUE_OUT" is missing, needed only if using Exim as MTA
conf.php: optional configuration entry "PWD_RESET_FROM_NAME" is missing, needed if Password Reset feature is enabled
conf.php: optional configuration entry "PWD_RESET_FROM_ADDRESS" is missing, needed if Password Reset feature is enabled
conf.php: optional configuration entry "MAIL_SENDER" is missing, needed if you use Exim or Sendmail Queue
conf.php: optional configuration entry "SESSION_NAME" is missing, needed if experiencing session conflicts
conf.php: optional configuration entry "USER_SELECTABLE_LANG" is missing, comma separated list of codes for languages the users can use eg. "de,en,fr,it,nl,pt_br"
conf.php: optional configuration entry "MAILWATCH_SMTP_HOSTNAME" is missing, needed only if you use a remote SMTP server to send MailWatch emails
conf.php: optional configuration entry "SESSION_TIMEOUT" is missing, needed if you want to override the default session timeout
Downloading file, please wait...
GeoIP IPv4 data file successfully downloaded
GeoIP IPv6 data file successfully downloaded
Download complete, unpacking files...
GeoIP IPv4 data file successfully unpacked
GeoIP IPv6 data file successfully unpacked
Process completed!
Starting httpd: [ OK ]
MailScanner starting ...
MailScanner started with process id 13465
3.0.2.3 update is complete
All done
Thank you for using E.F.A.
