Option 11 Apache Settings doesn't work?
Tried to enter menu 11 in the cli, but it doesn't actually enter Apache Settings. Am I missing something? (a daemon to be halted before entering that part?)
Re: Option 11 Apache Settings doesn't work?
Same here - Any suggestions? Rebooted server.
Thanks for the quick fix!
However, any option behind it, answering Y or n results in enabled either way.
I guess there is another if/then mismatch?
Works great. Thanks for the fix.
Now option 11 ignores N or n as an input and sets it to secure in any case.
yes, not we can not turn this option off, does anyone knows how to turn it off manually?
up 2 date?
check https://github.com/E-F-A/v3/blob/master ... hesettings
you could copy this code to your file (make a backup first)
deactivate the TLS port and
use the backuped file (so the upgrade would work)
