HTTPS in 3.0.0.9
HTTPS in 3.0.0.9
Hey guys, noticed in the update it lists https for web interface by default. Before I update, I wanted to ask does it redirect http to https? because I only have a single static at home with 80 for EFA and 443 for OWA. Also, will it create quarantine release links as https? If so how can I make changes for both to http again? Thanks and look forward to update!
Re: HTTPS in 3.0.0.9
ssh into EFA with your admin account (not root!)
Choose option 11 to configure http
sweet thanks for the heads up - I will update tonight and see how all goes. Thanks!
Recently upgraded to 3.0.1.0, and am seeing no affect when disabling the redirect from 80 to 443 via Option 11 in the console menu.
Is there any other approach to disable the HTTPS redirect that I can try?
RMS-ATR
Apache Settings
By default, EFA uses port 443
You can enable port 443 for secure access.
[EFA][ Enable port 443? (Y/n): n
iptables: Saving firewall rules to /etc/sysconfig/iptables: OK
Port 443 [Enabled][
If you have your own pki certificate, please copy the certificate to:
/etc/pki/tls/certs/localhost.crt
and copy the private key to:
/etc/pki/tls/private/localhost.key
Port 80 --> 443 Redirect
You can choose to redirect all port 80 traffic to port 443
[EFA][ Redirect port 80 to port 443? (Y/n): n
Port 80 to 443 redirection [Enabled][
Reloading httpd:
RMS-ATR
Bug. See viewtopic.php?f=13&t=1619 for a fix
