Hi All,
I am new to EFA, but managed to get a VM appliance running nicely after some fiddling. I wanted to set up a physical box with EFA to do the same job so we bought a NUC to house this. the setup of that seemed to go all fine, however when we put it in place it seemed to catch all the inbound mail and not deliver any of it? I cant see anything different in our setups of the VM or the physical box.
There appeared to be a problem with clam av so we tried uninstalling and re installing, but i think we made things worse.
Is there a method of transferring everything from the working VM environment to the not working NUC (Physical) one? Or am i best just to rebuild from scratch? (this is a little hard as the NUC is in a China office, but we can get the NUC shipped back).
Thanks for your time!
Transfer VM setup to Physical?
Re: Transfer VM setup to Physical?
You will want to build from scratch on a physical box. VM cannot be transferred to physical (actual hardware present).
See the wiki for more info: https://efa-project.org/wiki/Building_E.F.A.
just out of interest, why not virtualise on the NUC ?
