i just have installed EFA 0.3
does anyone had an issues of missing emails on the filter and did you solve it?
to make sure all email are passing through, i have all emails relay through ESVA 1.7 to EFA 0.3.
i have noticed some clean email that gets to ESVA 1.7 doesn't even registor at EFA 0.3 (majority of the email works fine).
i am sure nothing is wrong with the ESVA 1.7
Missing emails
Re: Missing emails
just turned off EFA, have received couple of complains.
Re: Missing emails
If you relay all mails from 1 host through an other host then you might get some problems.
As EFA tries to validate all mail receiving using SPF, then most mail's that are send from an SPF enabled domain/host will get blocked on the MTA level (so not even visible in the EFA GUI)
Also the rate limiter might kick in when you receive lots of mail.
so that might be your issue.
Re: Missing emails
thank you,
i tryed sending mails directly to the EFA. it is rejected all email by the server and sends "The error that the other server returned was:
500 5.3.3 Unrecognized command".
would you able to suggest a solution for the issues.
