unable to preview messages
Posted: 29 Jan 2013 21:31
by ge2000
Almost everything is working fine. Except when trying to view a message like
http://efa/messages/preview/07A16B3ACF.AEA52 an error is shown.
The message is:
Page unavailable
Sorry the requested page is unavailable due to a server malfunction.
Have I broke something or does anyone know where to look?
Kind regards,
Ge
Re: unable to preview messages
Posted: 30 Jan 2013 07:30
by darky83
This should be logged in the baruwa log file:
/var/log/baruwa/celeryd.log
this is most likely a rabbitmq connection error.
Posted: 30 Jan 2013 09:02
by ge2000
You're right. There are hundreds of these errors. Although everything else seems to work fine I assume there is more broken than the preview only.
I will look into this but if you have any suggestions to start with please let me know.
Thanks,
Ge
[2013-01-30 10:41:41,384: ERROR/MainProcess] Consumer: Connection Error: Socket closed. Trying again in 32 seconds...
[2013-01-30 10:42:16,421: ERROR/MainProcess] Consumer: Connection Error: Socket closed. Trying again in 32 seconds...
[2013-01-30 10:42:51,445: ERROR/MainProcess] Consumer: Connection to broker lost. Trying to re-establish connection...
Traceback (most recent call last):
File "/usr/lib/pymodules/python2.6/celery/worker/consumer.py", line 274, in start
self.reset_connection()
File "/usr/lib/pymodules/python2.6/celery/worker/consumer.py", line 483, in reset_connection
self.connection = self._open_connection()
File "/usr/lib/pymodules/python2.6/celery/worker/consumer.py", line 529, in _open_connection
self.app.conf.BROKER_CONNECTION_MAX_RETRIES)
File "/usr/lib/pymodules/python2.6/kombu/connection.py", line 184, in ensure_connection
interval_start, interval_step, interval_max)
File "/usr/lib/pymodules/python2.6/kombu/utils/__init__.py", line 102, in retry_over_time
return fun(*args, **kwargs)
File "/usr/lib/pymodules/python2.6/kombu/connection.py", line 119, in connect
return self.connection
File "/usr/lib/pymodules/python2.6/kombu/connection.py", line 444, in connection
self._connection = self._establish_connection()
File "/usr/lib/pymodules/python2.6/kombu/connection.py", line 410, in _establish_connection
conn = self.transport.establish_connection()
File "/usr/lib/pymodules/python2.6/kombu/transport/pyamqplib.py", line 252, in establish_connection
connect_timeout=conninfo.connect_timeout)
File "/usr/lib/pymodules/python2.6/kombu/transport/pyamqplib.py", line 51, in __init__
super(Connection, self).__init__(*args, **kwargs)
File "/usr/lib/pymodules/python2.6/amqplib/client_0_8/connection.py", line 140, in __init__
(10, 30), # tune
File "/usr/lib/pymodules/python2.6/amqplib/client_0_8/abstract_channel.py", line 89, in wait
self.channel_id, allowed_methods)
File "/usr/lib/pymodules/python2.6/amqplib/client_0_8/connection.py", line 198, in _wait_method
self.method_reader.read_method()
File "/usr/lib/pymodules/python2.6/amqplib/client_0_8/method_framing.py", line 215, in read_method
raise m
IOError: Socket closed
[2013-01-30 10:42:54,449: ERROR/MainProcess] Consumer: Connection Error: Socket closed. Trying again in 2 seconds...
[2013-01-30 10:42:59,456: ERROR/MainProcess] Consumer: Connection Error: Socket closed. Trying again in 4 seconds...
Posted: 30 Jan 2013 09:41
by ge2000
ok, found that baruwa password was wrong. After changing it the errors are gone. Will do some more testing.....
root@efa1:/var/log/rabbitmq# rabbitmqctl change_password baruwa ***************
Changing password for user "baruwa" ...
...done.
Edit: It works fine now..... no idea why the installation password wasn't working
Posted: 27 Mar 2013 16:53
by mw308
Hi Ge
I am getting the same error and according to the rabbitmq log the user baruwa cannot log onto the database. In my install (script not VM as using Hyper-V) it chose a random password for the baruwa user which is encrypted in the config files - how did you know what to change it to in rabbitmqctl?
Many thanks in advance
Posted: 27 Mar 2013 17:36
by darky83
The build script creates a random password and puts this random password in the config files and sets this random password in rabbitmq
If you change the rabbitmq password manually you should also change this in the baruwa config file: /etc/baruwa/settings.py
look for:
Then restart baruwa and you should be ready to go.
Posted: 28 Mar 2013 08:47
by mw308
Changing it as above appears to work perfectly.
Many thanks!
