problem after installation with Mailscaner
mami
Post by mami »
After instalations I get error in postfix log like:
Jan 7 16:15:12 smtp-efa1 postfix/smtpd[54739]: connect from mail134.domain.ltd [94.xxx.xxx.xxx]
Jan 7 16:15:12 smtp-efa1 postfix/smtpd[54739]: warning: connect to Milter service inet:127.0.0.1:33333: Connection refused
Jan 7 16:15:12 smtp-efa1 postfix/smtpd[54739]: NOQUEUE: milter-reject: CONNECT from mail134.domain.ltd [94.xxx.xxx.xxx]: 451 4.7.1 Service unavailable - try again later; proto=SMTP
Jan 7 16:15:12 smtp-efa1 postfix/smtpd[54739]: NOQUEUE: milter-reject: EHLO from mail134.domain.ltd [94.xxx.xxx.xxx]: 451 4.7.1 Service unavailable - try again later; proto=SMTP helo=<mail134.domain.ltd>
Jan 7 16:15:12 smtp-efa1 postfix/smtpd[54739]: NOQUEUE: milter-reject: MAIL from mail134.domain.ltd [94.xxx.xxx.xxx]: 451 4.7.1 Service unavailable - try again later; from=<root@mail134.domain.ltd> proto=ESMTP helo=<mail134.domain.ltd>
My os is a Centos-8x in vmware
ps -aux
52565 ? S 0:00 MailWatch SQL
52567 ? Ss 0:00 MailScanner: master process sleeping
52568 ? S 0:01 MailScanner: waiting for messages
52614 ? S 0:01 MailScanner: waiting for messages
52730 ? S 0:01 MailScanner: waiting for messages
52905 ? S 0:01 MailScanner: waiting for messages
in netstat I canoot find 33333
tcp 0 0 0.0.0.0:587 0.0.0.0:* LISTEN 44598/master
tcp 0 0 0.0.0.0:10000 0.0.0.0:* LISTEN 15066/perl
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 8559/httpd
tcp 0 0 127.0.0.1:53 0.0.0.0:* LISTEN 37544/pdns_recursor
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 1601/sshd
tcp 0 0 0.0.0.0:25 0.0.0.0:* LISTEN 44598/master
tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN 8559/httpd
tcp 0 0 0.0.0.0:222 0.0.0.0:* LISTEN 1601/sshd
tcp 0 0 127.0.0.1:11553 0.0.0.0:* LISTEN 52565/MailWatch SQL
tcp 0 0 0.0.0.0:873 0.0.0.0:* LISTEN 1110/rsync
tcp 0 0 127.0.0.1:3306 0.0.0.0:* LISTEN 1831/mysqld
tcp6 0 0 :::587 :::* LISTEN 44598/master
tcp6 0 0 :::10000 :::* LISTEN 15066/perl
tcp6 0 0 :::22 :::* LISTEN 1601/sshd
tcp6 0 0 :::25 :::* LISTEN 44598/master
tcp6 0 0 :::222 :::* LISTEN 1601/sshd
tcp6 0 0 :::873 :::* LISTEN 1110/rsync
udp 0 0 0.0.0.0:10000 0.0.0.0:* 15066/perl
udp 0 0 127.0.0.1:53 0.0.0.0:* 37544/pdns_recursor
udp 0 0 127.0.0.1:323 0.0.0.0:* 1062/chronyd
In Mailscanner.conf
grep -ir "3333" /etc/*
/etc/firewalld/zones/public.xml: <port port="33333" protocol="tcp"/>
/etc/MailScanner/MailScanner.conf:Milter Port = 33333
/etc/MailScanner/MailScanner.conf.rpmsave:Milter Port = 33333
/etc/postfix/main.cf:smtpd_milters = inet:127.0.0.1:33333
Any idea ?
mami
Re: problem after installation with Mailscaner
Post by mami »
Im confused .... and I dont known where is a problem
clear install in mailllog:
Jan 10 14:02:20 smtp-efa1 MailScanner[9092]: MailWatch: SQLSpamSettings:: Read 1 Spam entries
Jan 10 14:02:20 smtp-efa1 MailScanner[9092]: Config: calling custom init function SQLBlacklist
Jan 10 14:02:20 smtp-efa1 MailScanner[9092]: MailWatch: Starting up MailWatch SQL Blocklist
Jan 10 14:02:20 smtp-efa1 MailScanner[9092]: MailWatch: Read 1 blocklist entries
Jan 10 14:02:20 smtp-efa1 MailScanner[9092]: Config: calling custom init function SQLHighSpamScores
Jan 10 14:02:20 smtp-efa1 MailScanner[9092]: MailWatch: SQLSpamSettings:: Read 1 high Spam entries
Jan 10 14:02:20 smtp-efa1 MailScanner[9092]: Config: calling custom init function SQLWhitelist
Jan 10 14:02:20 smtp-efa1 MailScanner[9092]: MailWatch: Starting up MailWatch SQL Allowlist
Jan 10 14:02:20 smtp-efa1 MailScanner[9092]: MailWatch: Read 0 allowlist entries
Jan 10 14:02:20 smtp-efa1 MailScanner[9092]: Config: calling custom init function MailWatchLogging
Jan 10 14:02:20 smtp-efa1 MailScanner[9092]: MailWatch: Started MailWatch SQL Logging child
Jan 10 14:02:20 smtp-efa1 MailScanner[9092]: Using SpamAssassin results cache
Jan 10 14:02:20 smtp-efa1 MailScanner[9092]: Connected to SpamAssassin cache database
Jan 10 14:02:20 smtp-efa1 MailScanner[9092]: Enabling SpamAssassin auto-whitelist functionality...
Jan 10 14:02:22 smtp-efa1 MailScanner[9092]: Using locktype = flock
Jan 10 14:02:25 smtp-efa1 MailScanner[9098]: MailScanner Email Processor version 5.4.2 starting...
Jan 10 14:02:25 smtp-efa1 MailScanner[9098]: Reading configuration file /etc/MailScanner/MailScanner.conf
Jan 10 14:02:25 smtp-efa1 MailScanner[9098]: Reading configuration file /etc/MailScanner/conf.d/README
Jan 10 14:02:25 smtp-efa1 MailScanner[9098]: Read 1500 hostnames from the phishing whitelist
Jan 10 14:02:25 smtp-efa1 MailScanner[9098]: Read 4064 hostnames from the phishing blacklists
Jan 10 14:02:25 smtp-efa1 MailScanner[9098]: Config: calling custom init function MailWatchLogging
Jan 10 14:02:25 smtp-efa1 MailScanner[9098]: MailWatch: Started MailWatch SQL Logging child
Jan 10 14:02:25 smtp-efa1 MailScanner[9098]: Config: calling custom init function SQLWhitelist
root@smtp-efa1 ~]# MailScanner --lint
Trying to setlogsock(unix)
Config: calling custom init function SQLSpamScores
Checking version numbers...
Version number in MailScanner.conf (5.4.2) is correct.
Your envelope_sender_header in spamassassin.conf is correct.
MailScanner setting GID to (89)
MailScanner setting UID to (89)
Checking for SpamAssassin errors (if you use it)...
SpamAssassin reported no errors.
Using locktype = posix
MailScanner.conf says "Virus Scanners = clamd"
Found these virus scanners installed: clamd
Filename Checks: Windows/DOS Executable (1 eicar.com)
Other Checks: Found 1 problems
Clamd::INFECTED:: {HEX}EICAR.TEST.3.UNOFFICIAL :: ./1/eicar.com
Virus Scanning: Clamd found 2 infections
Infected message 1 came from 10.1.1.1
Virus Scanning: Found 2 viruses
Virus Scanner test reports:
Clamd said "eicar.com was infected: {HEX}EICAR.TEST.3.UNOFFICIAL"
If any of your virus scanners (clamd)
Config: calling custom end function SQLBlacklist
MailWatch: Closing down MailWatch SQL Blocklist
Config: calling custom end function MailWatchLogging
Config: calling custom end function SQLWhitelist
MailWatch: Closing down MailWatch SQL Allowlist
Config: calling custom end function SQLHighSpamScores
MailWatch: SQLSpamSettings:: Closing down MailWatch SQL High Spam Scores
Config: calling custom end function SQLSpamScores
MailWatch: SQLSpamSettings:: Closing down MailWatch SQL Spam Scores
ps -aux
8823 ? Ss 0:00 MailScanner: master process sleeping
8824 ? S 0:01 MailScanner: waiting for messages
8864 ? S 0:01 MailScanner: waiting for messages
8898 ? S 0:01 MailScanner: waiting for messages
8908 ? S 0:01 MailScanner: waiting for messages
9073 ? S 0:01 MailScanner: waiting for messages
9080 ? S 0:01 MailScanner: waiting for messages
9086 ? S 0:01 MailScanner: waiting for messages
9092 ? S 0:01 MailScanner: waiting for messages
9098 ? S 0:01 MailScanner: waiting for messages
9104 ? S 0:01 MailScanner: waiting for messages
and problem still exists
warning: connect to Milter service inet:127.0.0.1: Connection refused
When you log into the GUI do you see a message in the footer?
