Dear All,
I have saw an issue and i would like to know if there is a bugfix or if i have to check :
When a customer send an email with winmail.dat attachement and in the email content + attached files, if the files have the more or less same name structure like « CONFIRMATION-123-p1.pdf » « CONFIRMATION-123-p2.pdf » « CONFIRMATION-123-p3.pdf » then the attachement is overrides ! Then the files p1 and p2 have the same content of the last file (written in last by mail scanner)
Any idea ? If not, i will create a small fix..
The release is 4.0.4.
Regards
Philippe
Winmail.dat TNEF Attachment Extraction Override issue
Re: Winmail.dat TNEF Attachment Extraction Override issue
Did you identify a fix for this?
