New Install on centos 7 fails - mariadb101u-server is gone
jens
Post by jens »
the build script fails, as it can not resove mariadb101u-server
Error: Package: 1:eFa-4.0.4-13.eFa.el7.noarch (eFa4)
           Requires: mariadb101u-server >= 1:10.1.35-1
for now i try with
yum install mariadb104-server mariadb104-server-utils mariadb104-backup mariadb104 mariadb104-devel mariadb104-libs
next i copied the build script changed to
yum -y install eFa --skip-broken >> $LOGFILE 2>&1
looks good so far:
2021.07.11-10:07:47 - eFa4 Installed
2021.07.11-10:07:47 - ============  EFA4 BUILD SCRIPT FINISHED  ============
2021.07.11-10:07:47 - ============  PLEASE REBOOT YOUR SYSTEM   ============
Do you wish to reboot the system now? (Y/N):
But more things are to new :-(
yum install eFa-4.0.0
Error: Package: 1:eFa-4.0.0-67.eFa.el7.x86_64 (eFa4)
           Requires: php72u-cli >= 7.2.13-2
           Requires: php72u-mbstring >= 7.2.13-2
           Requires: php72u-json >= 7.2.5-2
           Requires: php72u-gd >= 7.2.13-2
           Requires: php72u-xml >= 7.2.13-2
           Requires: php72u-ldap >= 7.2.13-2
Error: php74-common conflicts with php-common-5.4.16-48.el7.x86_64
           Requires: php72u-fpm >= 7.2.5-2
           Requires: php72u-mysqlnd >= 7.2.13-2
           Requires: php72u-process >= 7.2.5-2
           Requires: php72u >= 7.2.13-2
But
yum search php | grep 7 shows no php72 anymore, only php73 or php74
so i guess my old centos 7 is too modern.....
Re: New Install on centos 7 fails - mariadb101u-server is gone
Unfortunately, this will cause further problems. You won't make it very far during setup.
I am working on fixes.
jens
Post by jens »
( never ask for eta...)
i'm happy to see eFa 5 on debian - i like it...
as Centos 8 has EOL this year using Centos 7 was need :-(
jens
Should be fixed now, just updated the repo.
jens
Post by jens »
Yes, thanks looks very good.
As well migration from V3.0.2.6 :-)
Just the LDAP AD stuff has to go from conf.php.v3 to the conf.php
very fast response, thanks again for your work
jens
bikertrash
Post by bikertrash »
Yeah, just ran into this same thing this morning. Currently on eFa-4.0.4. Am I out of date?
Part of my morning routine is to check all of 16 of my Linux servers for any updates / upgrades.
mikeyg79
Post by mikeyg79 »
bikertrash wrote: 12 Jul 2021 13:06 Yeah, just ran into this same thing this morning. Currently on eFa-4.0.4. Am I out of date?
I just ran into this too. It seems upgrading MariaDB 10.1 to MariaDB 10.2 is a major release - have to uninstall 10.1 and install 10.2
At least looking at https://mariadb.com/kb/en/upgrading-fro ... riadb-102/
Going to make a backup image of our system tonight and manually try to upgrade MariaDB, then do the upgrade for eFa - hope it works.
bikertrash
mikeyg79 wrote: 12 Jul 2021 20:02 I just ran into this too. It seems upgrading MariaDB 10.1 to MariaDB 10.2 is a major release - have to uninstall 10.1 and install 10.2
Hmm... after reading this, I went looking for the procedure to do that. Looks a bit spooky to me since my knowledge of Centos is a bit sketchy at best. Going to wait for your report and then perhaps take a crack at it here. Fortunately, mine is running on a VM so I can easily create a checkpoint end roll back to it if I manage to dork it all up. :D
bikertrash
Although mine is not a new installation and as I mentioned above, I ran into this same error when checking for and attempting to install the latest update the other morning.
In my case it turned out to be a rather easy fix to upgrade MariaDB and then the EFA update installed without issue. Since I'm running this appliance as a Hyper-V guest, I first created a checkpoint and then from a command prompt while logged in as the root user, a "yum update" did the trick. After that, I restarted the appliance and ran some incoming and outgoing mail tests and all was well.
