henk wrote: ↑30 Jul 2021 09:16
However my token-table still does not populate
Works fine over here.
Can you run?
spamassassin -D --lint 2>&1 | grep bayes:
Jul 30 12:45:54.446 [2723] dbg: bayes: learner_new self=Mail::SpamAssassin::Plugin::Bayes=HASH(0x4e89650), bayes_store_module=Mail::SpamAssassin::BayesStore::SQL
Jul 30 12:45:54.542 [2723] dbg: bayes: using username: postfix
Jul 30 12:45:54.542 [2723] dbg: bayes: learner_new: got store=Mail::SpamAssassin::BayesStore::SQL=HASH(0x55d4cf0)
Jul 30 12:45:54.819 [2723] dbg: bayes: database connection established
Jul 30 12:45:54.832 [2723] dbg: bayes: found bayes db version 3
Jul 30 12:45:54.832 [2723] dbg: bayes: Using userid: 1
Jul 30 12:45:54.889 [2723] dbg: bayes: corpus size: nspam = 4337, nham = 68686
Jul 30 12:45:54.890 [2723] dbg: bayes: tokenized body: 120 tokens
Jul 30 12:45:54.891 [2723] dbg: bayes: tokenized uri: 0 tokens
Jul 30 12:45:54.891 [2723] dbg: bayes: tokenized invisible: 0 tokens
Jul 30 12:45:54.892 [2723] dbg: bayes: tokenized header: 14 tokens
Jul 30 12:45:54.893 [2723] dbg: bayes: tok_get_all: token count: 20
Jul 30 12:45:54.896 [2723] dbg: bayes: score = 0.49176563485452
Jul 30 12:45:55.297 [2723] dbg: timing: total 2858 ms - init: 2401 (84.0%), b_tie_ro: 290 (10.1%), parse: 1.36 (0.0%), extract_message_metadata: 6 (0.2%), get_uri_detail_list: 2.7 (0.1%), tests_pri_-1000: 10 (0.3%), compile_gen: 151 (5.3%), compile_eval: 26 (0.9%), tests_pri_-950: 6 (0.2%), tests_pri_-900: 7 (0.2%), tests_pri_-100: 6 (0.2%), tests_pri_-90: 22 (0.8%), check_bayes: 13 (0.5%), b_tokenize: 4.0 (0.1%), b_tok_get_all: 2.6 (0.1%), b_comp_prob: 0.26 (0.0%), b_tok_touch_all: 2.9 (0.1%), b_finish: 1.65 (0.1%), tests_pri_0: 280 (9.8%), tests_pri_10: 6 (0.2%), tests_pri_20: 6 (0.2%), tests_pri_30: 6 (0.2%), tests_pri_500: 86 (3.0%), tests_pri_1000: 7 (0.2%)
About the already running mysql, can you check. Just want to know.
mysqld does not exist, so I used mariadb
● mariadb.service - MariaDB 10.2 database server
Loaded: loaded (/usr/lib/systemd/system/mariadb.service; disabled; vendor preset: disabled)
Drop-In: /etc/systemd/system/mariadb.service.d
└─limit.conf, override.conf
Active: active (running) since Mon 2021-07-26 18:32:46 CEST; 3 days ago
Docs: man:mysqld(8)
https://mariadb.com/kb/en/library/systemd/
Main PID: 2080 (mysqld)
Status: "Taking your SQL requests now..."
CGroup: /system.slice/mariadb.service
└─2080 /usr/libexec/mysqld --basedir=/usr
