CensOS 8.4 has a newer SpamAssassin version (3.4.4-3) without sa-compile. This results into a failed daily cron job of SpamAssassin.
Please upgrade the custom SpamAssassin of eFA package to be up-to-date with latest SpamAssassin including sa-compile.
sa-comile is missing with upgrade to CentOS 8.4
Re: sa-comile is missing with upgrade to CentOS 8.4
Seeing this as well.
Everyday I get this email from `Anacron`:
Subject: Anacron job 'cron.daily' on <server>
Body:
/etc/cron.daily/mailscanner:
which: no sa-compile in (/sbin:/bin:/usr/sbin:/usr/bin:/usr/sbin:/usr/local/sbin:/usr/bin:/usr/local/bin:/bin:/sbin)
Body:
Yep aware, going to fix soon
Did they manage to fix this bug? Would you have a prediction? What impact will I have if I can't enable this feature?
This should be resolved.
