Hi all,
I just tried to get eFa 4 installed on CentOS8 via build.bash
First problem I realized is the section "Enabling CentOS 8 PowerTools Repo", which stopped with "No such command: config-manager. Please use /usr/bin/yum --help".
Easy fix -> "yum install 'dnf-command(config-manager)'"
Next problem, I do not come around is "Installing eFa packages (This can take a while)", which stops with "ERROR: eFa4 failed to install"
A manual "yum -y install eFa" ends with
Error:
Problem: package eFa-1:4.0.3-2.eFa.el8.noarch requires postfix_eFa >= 3.4.8-1, but none of the providers can be installed
- conflicting requests
- nothing provides libmysqlclient.so.21()(64bit) needed by postfix_eFa-2:3.4.8-1.eFa.el8.x86_64
- nothing provides libmysqlclient.so.21(libmysqlclient_21.0)(64bit) needed by postfix_eFa-2:3.4.8-1.eFa.el8.x86_64
Obviously, there is some mysql/mariadb library missing, a "dnf install mariadb-server" did not do the trick...
Greets,
Stefan
CentOS 8 installation error - libmysqlclient.so.21
Re: CentOS 8 installation error - libmysqlclient.so.21
Taking a look. Did you install from the CentOS 8 distribution, or is this a Cloud-based instance, and if so, which provider?
Unable to reproduce using CentOS-8.2.2004-x86_64-minimal.iso on KVM.
Will need more details to continue troubleshooting.
Hi Shawn,
Thank you for taking the time to look into this.
The system is a VPS from a big german provider, Strato, tt's an OpenVZ instance
Regarding the system, as customer you cannot install the system yourself at all, like a "cloud instance", you hit the button and then there is your system.
I hope this helps.
Regards,
Stefan
I hope this helps.
Regards,
Stefan
It appears that Strato does not do business with US-based customers. I am unable to establish a VPS with them for testing since I do not have an EU-based address.
We will need to troubleshoot this together.
First, please share with me the contents of /etc/centos-release
Hi Shawn,
Again, thank you.
I'd suggest to give you direct access to mentioned system (a PM with credential will follow) -> makes your and my life easier!
I am hitting the "reinstall" button for that instance now, so should be "Strato vanilla CentOS 8" in roughly 20 minutes.
Since that system is non-productive now and will be "reset" after debugging, please feel free to mess around like you wish.
Greets,
Stefan
Again, thank you.
Greets,
Stefan
PM is with you Shawn.
Have fun
Have fun
