Cannot Edit MailScanner Rulesets
Posted: 13 Apr 2020 07:09
by gtao725
Hello Community,
Does anyone have the same issue as I am having on the latest eFa 4.0.2? I cannot seem to edit any MailScanner Rulesets. Even after giving chmod 777 permissions to the ruleset files didnt help. Pls see attachments. Any help would be greatly appreciated. Thx in advance!
Re: Cannot Edit MailScanner Rulesets
Posted: 16 Apr 2020 06:11
by gtao725
Hello Community,
I did find this
viewtopic.php?t=1973 but according to the post this issue was supposed to have been fixed already and I am using the default en webgui of efa 4.0.2.
Posted: 16 Apr 2020 07:19
by gtao725
Checked the /var/log/php-fpm/www-error.log and found some errors when executing php scripts from the MSRE rule edit page. Is there a solution to this?
Posted: 18 Apr 2020 15:32
Good 'ole permissions. Taking a look...
Posted: 18 Apr 2020 15:40
Posted: 20 Apr 2020 07:31
by gtao725
Thx for making it an issue to be fixed on github. Guess I will use cli to make all the rules for the time being.
Posted: 20 Nov 2020 08:56
by sergiupapuc
I have the same error with actual version! ...automatic update are on...
Posted: 21 Nov 2020 14:41
Can you give us a little more detail please?
Posted: 22 Nov 2020 11:13
by sergiupapuc
...exactly like in the start of this post, but on uptodate sistem!
Posted: 22 Nov 2020 12:46
