[Solved] Cron error message /usr/share/clamav/freshclam-sleep
Posted: 23 Mar 2020 18:37
Since a this weekend I am getting this message:
I have no idea why and where I should look into to slove the problem.
Somebody out there with a soloution for me?
Update:
The a.m. path was not existing, created it and symlinked from
rebooted and everything was running.
However, I do not know what caused this problem, maybe a recent yum upgrade?
BR Andreas
ERROR: Download failed (77) ERROR: Message: Problem with the SSL CA cert (path? access rights?)
ERROR: getpatch: Can't download daily-25758.cdiff from https://database.clamav.net/daily-25758.cdiff
ERROR: getcvd: Can't download daily.cvd from https://database.clamav.net/daily.cvd
ERROR: Update failed for database: daily
ERROR: Database update process failed: Connection failed (5)
ERROR: Update failed.
Update:
successfully set certificate verify locations:
* CAfile: /usr/share/ssl/certs/ca-bundle.crt
CApath: none
/etc/ssl/certsHowever, I do not know what caused this problem, maybe a recent yum upgrade?
BR Andreas
