EFA4.0 rc3 updates
Posted: 09 Sep 2019 12:00
by tesme33
loking into the "yum update" output i would assume that rc3 will not get udates .
But will we be able t just change the repository once 4.0 has been released or do we need to reinstall ?
[root@efa4 postfix]# yum update
Loaded plugins: fastestmirror
 * base: mirror.checkdomain.de
 * eFa4-Testing: dl.efa-project.org
 * epel: ftp.fau.de
 * extras: mirror.checkdomain.de
 * updates: mirror.checkdomain.de
No packages marked for update
Re: EFA4.0 rc3 updates
Posted: 10 Sep 2019 21:12
No reinstall, just a repo change :)
Posted: 11 Sep 2019 05:17
by tesme33
thx. great.
Posted: 08 Nov 2019 08:18
by ItemsGmbH
So now eFa 4 is just released
How can i "upgrade" to stable from RC3? :D
Thx for your great work!
Posted: 08 Nov 2019 14:10
https://wiki.efa-project.org/doku.php?i ... _migration
:idea: Before you upgrade, take a look how to search this forum viewtopic.php?f=5&t=2974
Posted: 08 Nov 2019 14:22
by kommunen
The question was how to migrate from eFa4 rc3 to final. That's not mentioned in the eFa3 -> eFa4 page.
That said, the build.bash we currently get from https://install.efa-project.org still refers to the testing repo (https://dl.efa-project.org/rpm/eFa4/testing/x86_64).
That's either an oversight or a sign that all the final release rpms are in the rc repo. In the latter case a 'yum update' should do the trick.
Posted: 09 Nov 2019 13:51
kommunen wrote:
08 Nov 2019 14:22
I will post instructions later today. Very simple, just switch the repo from testing to the production one!
Posted: 09 Nov 2019 18:49
Posted: 11 Nov 2019 10:46
by Justin
Just a small note with the first command
Instead of
sudo rm /etc/yum.repos.d/eFa4-Testing.repo
I had to use
sudo rm /etc/yum.repos.d/eFa4-testing.repo
Otherwise i receive a file/folder not found
Posted: 11 Nov 2019 11:03
by ItemsGmbH
Same here, rest works like a charme :-)
Thanks a lot
Justin wrote:
11 Nov 2019 10:46
Instead of
I had to use
Posted: 11 Nov 2019 12:12
Fixed :D
Posted: 13 Nov 2019 12:42
by andreluizpr
Hello
I am trying to install eFa4 in a new environment with CentOS7 1908 but I am not succeeding. I noticed that this problem is occurring with different IP addresses located in Brazil.
When I try to download the eFa4.repo file this error occurs:
[BRA] # curl -L https://mirrors.efa-project.org/rpm/eFa4/eFa4.repo -o eFa4.repo
  % Total% Received% Xferd Average Speed ​​Time Time Time Current
                                 Dload Upload Total Spent Left Speed
  0 0 0 0 0 0 0 0 -: -: - 0:00:06 -: -: - 0
  0 0 0 0 0 0 0 0 -: -: - 0:00:21 -: -: - 0
curl: (35) TCP connection reset by peer
When I try to download it from an IP address located in the United States, I can:
[USA] # curl -L https://mirrors.efa-project.org/rpm/eFa4/eFa4.repo -o eFa4.repo
  0 0 0 0 0 0 0 0 -: -: - -: -: - -: -: - 0
100 168 100 168 0 0 206 0 -: -: - -: -: - -: -: - 206
I did the same process by pasting the URL into different browsers and using IPs from different countries and had the same scenario.
I downloaded the file to another machine located in the United States and copied the content to the machine located in Brazil but was unable to install eFa.
My build.log file
2019.11.13-09:31:38 - ============= EFA4 BUILD SCRIPT STARTING ============
2019.11.13-09:31:38 - Good you are root.
2019.11.13-09:31:38 - Good you are running CentOS 7
2019.11.13-09:31:38 - Checking network connectivity
2019.11.13-09:31:40 - OK - https://mirrors.efa-project.org is reachable
2019.11.13-09:31:40 - Updating the OS
Plugins carregados: fastestmirror
* base: mirror.ufscar.br
* eFa4: dl5.efa-project.org
* epel: mirror.uta.edu.ec
* extras: mirror.facom.ufms.br
* updates: mirror.facom.ufms.br
2019.11.13-09:31:48 - System Updated
2019.11.13-09:31:48 - Removing conflicting packages
2019.11.13-09:31:48 - Installing eFa packages (This can take a while)
All dependencies are resolved and packages are ready to install, but ... this error happens:
Downloading packages:
warning: /var/cache/yum/x86_64/7/eFa4/packages/postfix_eFa-3.3.0-1.eFa.el7.x86_64.rpm: Header V4 RSA / SHA1 Signature, key ID 108ef6b6: NOKEY
The public key for postfix_eFa-3.3.0-1.eFa.el7.x86_64.rpm is not installed
2019.11.13-09: 31: 52 - ERROR: eFa4 failed to install
2019.11.13-09: 31: 52 - ^^^^^^^^^^ SCRIPT ABORTED ^^^^^^^^^
André
Posted: 13 Nov 2019 15:57
Do you have a firewall/content filter/av scanner/IPS/something ahead of you interrupting your connection?
