Kiskstart not working properly
jon doe
Post by jon doe »
I have done more than a few kickstart installs in the past with no issues. Today I am not able to login after the install is finished.
Also I am not getting the initial login banner that displays the default password to login with. Since the install seems to go okay I am unable to login and see log files.
Any ideas on how to deal with this? I have tried twice with the same problem. I end up at a CentOS login shell which I cannot login to.
Thank you
Re: Kiskstart not working properly
Repository is broken at the moment.
jon doe
Post by jon doe »
Thanks for replying. I'll check it again later.
Repo back to order.
