Please answer yes or no. (install error)
Posted: 19 Aug 2019 15:52
Couple of oddities with this command on a fresh CentOS 7 Minimal install:
1) the installation fails unceremoniously with:
ERROR: eFa4 failed to install
From /var/log/eFa/build.log it became apparent that gpgcheck must be set to 0 in /etc/yum.conf due to the main eFa package not being signed.
2) the eFa installation process fails with an infinite loop of "Please answer yes or no.”
The actual output is:
<timestamp> - Installing eFa packages
<timestamp> - eFa 4 installed
<timestamp> - ============ EFA4 BUILD SCRIPT FINISHED ============
(repeat forever)
The fault is due to the reboot prompt not being permitted to receive input.
curl -sSL https://install.efa-project.org | bash
(repeat forever)
