IPv6 disable bug
Posted: 18 Apr 2019 12:18
Hi there,
When i try to disable IPv6 on our system i get the following error:
Steps are as followed:
4) IP Settings --> 6) Disable IPv6 --> Error
Any idea how to solve this?
Our IPv6 implementation is currently broken on one side so we are getting bounces from Gmail.
As a temporary fix, i want to disable it for now.
Running the latest eFa4 release
Kind regards,
Justin
/var/eFa/lib/eFa-Configure/func_ipsettings: line 94: Read: command not found
All done4) IP Settings --> 6) Disable IPv6 --> Error
Kind regards,
Justin
