Service unbound down
Posted: 04 Mar 2019 07:48
I keep receiving this error email after a few days.
Sadly, i cannot find the logfile which is needed to get more info.
eFa Monitor ALERT
Service unbound down and restarted ( 3 attempts in past day, max attempts is 3 )
Please examine your eFa logs on mx99.domain.nl and resources to determine cause of failure
Service unbound does give me this error:
[root@mx99 eFa]# service unbound status
Redirecting to /bin/systemctl status unbound.service
● unbound.service - Unbound recursive Domain Name Server
Loaded: loaded (/usr/lib/systemd/system/unbound.service; enabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Mon 2019-03-04 00:03:01 CET; 8h ago
Mar 04 00:03:01 mx99.domain.nl systemd[1]: Starting Unbound recursive Domain Name Server...
Mar 04 00:03:01 mx99.domain.nl unbound-checkconf[29880]: [1551654181] unbound-checkconf[29880:0] error: cannot parse forward . ip address: 'forward-addr:'
Mar 04 00:03:01 mx99.domain.nl unbound-checkconf[29880]: [1551654181] unbound-checkconf[29880:0] fatal error: Could not set forward zones
Mar 04 00:03:01 mx99.domain.nl systemd[1]: unbound.service: control process exited, code=exited status=1
Mar 04 00:03:01 mx99.domain.nl systemd[1]: Failed to start Unbound recursive Domain Name Server.
Mar 04 00:03:01 mx99.domain.nl systemd[1]: Unit unbound.service entered failed state.
Mar 04 00:03:01 mx99.domain.nl systemd[1]: unbound.service failed.
eFa Monitor ALERT
