[SOLVED] An error occured while sending the quarantine report.
Posted: 08 Feb 2019 15:09
by stefandewal
When manually sending the quarantine report i get this error:
I see nothing strange in apache error log, postfix log or php-fpm log
Does anyone have any ideas?
Re: An error occured while sending the quarantine report.
Posted: 08 Feb 2019 22:42
Sounds like a SELinux denial.
If you try this and send the message, do you get some interesting output?
sudo tail -f /var/log/audit/audit.log | grep -i denied
Posted: 10 Feb 2019 07:14
by stefandewal
shawn, i found it. it was really simple. i edited conf.php en set debug to true
after that i saw that i edited postfix a bit to much.
i only let postfix listen on 2 wan ip adresses and not localhost
So mailwatch couldnt connect to localhost
Re: [SOLVED] An error occured while sending the quarantine report.
Posted: 10 Feb 2019 15:03
