Missing parts
Posted: 07 Jan 2019 14:09
by Woger
I am missing DMARC and letsencrypt, Also the possibility to turn off grey listing. Is that still coming?
Greetings,
Roger
Re: Missing parts
Posted: 07 Jan 2019 21:06
Greylisting should be present already.
DMARC and letsecrypt are removed temporarily and will be added back after I rewrite them. The scripts were pretty awful.
Re: Missing parts
Posted: 08 Jan 2019 08:11
by Woger
Ok great,
So the possibility to disable grey listing is added allready?
Also, I had some problems while installing. I addressed it in an other post. Not sure if it is important, but the solution was adding the installation of php70u-cli to the install script.
Concerning DMARC and Letsencrypt, testing v4 is mainly possible in a live environment because you need quiet some mails to learn Bayes. So I want to use my own domains mail to get filtered by v4. However without DMARC and letsencrypt it's a no go for me nad probably others. So maybe it's better to have some awful, but working, scripts that are replaced later, than no at all.
Then, I installed V4 last week, but you do updates all the time. What is the best way to keep the system uptodate?
Greetings,
Roger
Re: Missing parts
Posted: 08 Jan 2019 11:08
Woger wrote: 08 Jan 2019 08:11 Ok great,
Greetings,
Roger
I added the missing php70u-cli.
It is not hard to add DMARC and letsencrypt yourself in the meantime. If you want, grab the v3 scripts and modify/run them.
This is a testing repository. I am not releasing incremental updates yet until everything is passing because that increases the workload substantially and I am making fundamental changes to the packages currently. You will need to rebuild if you want the latest to test right now.
Re: Missing parts
Posted: 22 Jan 2019 11:39
by jamerson
i am just curious,
why would you need letsencrypt for testing ?
EFAV4 encrypt the emails either you have a https or not in the apache.
or you mean the extern users will have issue with the irritant ssl error ?
Re: Missing parts
Posted: 22 Jan 2019 16:19
On your current efa
1) sa-learn --backup > backup.txt
on the new efa4
2) sa-learn --clear (this is optional, but good to do to clear out the old database)
4) Restore on efa4:
sa-learn --restore backup.txt
