Webmin installation after installing EFA, option 17
Posted: 04 Feb 2021 12:08
by andreas
I did fresh install of EFA yesterday, and i wanted to install Webmin as well, i choose option 17, after that I had to fill in a root password, the setupscripts calls a perl file and there is an error on line 6 I believe.
original:
#!/usr/bin/perl
# changepass.pl
# Script for the user to change their webmin password
# Check command line arguments
require "./acl/md5-lib.pl";
this didn't work
I changed it to
require "/usr/libexec/webmin//acl/md5-lib.pl";
and this works!
So maybe you can look at this and include this, or a better option into the code.
Re: Webmin installation after installing EFA, option 17
Posted: 05 Feb 2021 11:37
I wonder if a newer webmin has this fixed? I'll find out.
