Hide Whitelisted Emails Button/Setting
buonleloi
Post by buonleloi »
Can you add this feature to the Recent Mail Dashboard ?
It may useful to take a quick check and add new email address to B/W list.
Re: Hide Whitelisted Emails Button/Setting
You can achieve the same result by creating a filter for the Search and Reports.
For example, set the following under "Add Filter"
  • is Whitelisted
  • is equal to
  • 0
Then give it a name under "Load/Save Filter", like "not whitelisted" and save it.
Then it will always appear as an option under the Load/Save filter menu.
