Can you add a option to change existed domains in EFA-Configure -> 8 -> 4?
I need only change the destination, but I cant see that option yet.
Change IP address Postfix transport
Re: Change IP address Postfix transport
So you just need an option to change the second field, right?
Yes, edit domains and then only change the destination, can be a hostname or IP address.
