It would be nice, if it was possible to enter the unique identifier in the URL for ClamAV updates from securiteinfo.com during configuration - so that the customurl's could be added automatically to freshclam.conf (if no UID from the securiteinfo.com URL's is entered, no modifications should be done to the config).
It will probably require root access via SSH to be enabled during configuration - and then let the user decide whether root login should be permitted via SSH after configuration.
/Brian
Enter UID for securiteinfo.com URL's for ClamAV updates during config
Re: Enter UID for securiteinfo.com URL's for ClamAV updates during config
I actually did this change on my CentOS 7.x template... the code just needs to be included in the official EFA repo...
/B
/B
