Hi to all!
Like Subject, i set efamx as MTA relay on my Zimbra 8.0.7 server. if i send mail with Read-Receipt, efa purge header and remove the Read-Receipt TAG.
Anyone as the same problem or there is a way to solve this issue?
thanks and regards
[SOLVED] Read-Receipt missing with Zimbra 8.0.7
Re: Read-Receipt missing with Zimbra 8.0.7
What do you have in /etc/MailScanner/MailScanner.conf on the following line...
Remove These Headers =
Remove These Headers = X-Mozilla-Status: X-Mozilla-Status2: Disposition-Notification-To: Return-Receipt-To:shawniverson wrote:What do you have in /etc/MailScanner/MailScanner.conf on the following line...
You are fantastic!
Thanks for every works you do!
