Has anyone setup snmp monitoring of the queues.
i only ask as i use PRTG and would love to be able to get sms and email alerts
i found this http://kb.paessler.com/en/topic/21223-m ... on-postfix and will try to implement it.
Queue Monitoring via SNMP
Re: Queue Monitoring via SNMP
Hi sharktech,
Did it work? I am currently monitoring E.F.A.'s CPU, Memory, etc, via PRTG. I would like to monitor queues as well to be alerted if a problem occurs.
Let me know if it did work out for you.
Rafael
Rafael
I use Nagios to monitor the queue on my boxes, if that helps?
Sure! How do you do it? Do you use the script described here http://kb.paessler.com/en/topic/21223-m ... on-postfix ?b19wll wrote:I use Nagios to monitor the queue on my boxes, if that helps?
Or there is a simpler way?
