Delivering the full virus message
Is it possible to get EFA to deliver the full virus message along with a header that just marks it like "x-virus: infected" so that I can perform the quarantining process later in the delivery cycle?
Re: Delivering the full virus message
I'm not immediately seeing anything in MailScanner.conf or clamd.conf that can do this...it appears this may be hard coded into MailScanner to remove the infections.
After a lot of playing around I determined that it would be easier to write a cron job to call a script that would just POST the message files to a central REST API so I could control the entire thing at a central location. The server side script is dead simple since it just recieves a file and the date and the "code" and saves it to a centralized file storage where I can build a simple web UI for retrieving quarantine messages (or use any existing web app for this). If necessary I could also manually deliver the message but I think the REST API approach will work well for my needs.
If anyone reading this post in the future is interested in the script please contact me.
