I'm not sure what may have changed after my auto-update but now I'm seeing zipped viruses getting thru - is there anything I can check and do to kill them?
Rick -
Zipped virus files are getting thru - help!!
Re: Zipped virus files are getting thru - help!!
Check /etc/MailScanner/MailScanner.conf and look for maximum archive depth. This should be set to a positive value. I have used 3
