Enforcing inbound DKIM / DMARC
lukekenny
Post by lukekenny »
I want to run a fairly strict email filter for inbound email. I can get eFa to block incoming email with bad SPF records:
In /etc/mail/spamassassin/mailscanner.cf:
score SPF_FAIL 7.00
score SPF_SOFTFAIL 4.50
score SPF_HELO_FAIL 7.00
score SPF_NEUTRAL 3.00
How can I achieve a similar outcome for DKIM and DMARC fails?
I want to:
a. block email with a faulty / forged DKIM signature
b. block unsigned email where there is a DMARC record with "reject" set
Re: Enforcing inbound DKIM / DMARC
Do you see DKIMs in your spam score reports?
Aryfir
Post by Aryfir »
I suggest that you applied KAM.cf from https://mcgrail.com/downloads/
Then put high score on local.cf eg:
score KAM_DMARC_REJECT 10.0
score KAM_DMARC_QUARANTINE 3.0
