Massive spam attack - how to block?
Justin
Post by Justin »
Hi all,
I'm currently receiving a lot of spam email all to my domain.
They are not originating from our IP, so SPF is doing it's job but i still have a lagging spamfilter due too all spam emails.
Just for the idea, my Milter Inbound hasnt dropped under 2000 all day.
Any idea how i can block weber*@domain.com ? Black/whitelist does not support the * after weber.
Blocking the whole domain is not an option, since it's my own domain which is in use.
alorb88
Re: Massive spam attack - how to block?
Post by alorb88 »
Hello!
You can use regex to do that!!
Examples:
weber[a-z0-9]*@domain.com
weber[:[:alnum:][:punct:]:]*@domain.com
[:punct:] = punctuation characters
[:alnum:] = all numbers and letters
If you decide to use for others situations, think well before do that, to avoid block a lot of domains.
It's necessary to change some setup in postfix's file: /etc/postfix/main.cf
- If this does not a content in main.cf, add in the main.cf:
smtpd_sender_restrictions = regexp:/etc/postfix/sender_access
- If it is necessary, create the file /etc/postfix/sender_access
touch /etc/postfix/sender_access
- Include in /etc/postfix/sender_access
example 1:
weber[:[:alnum:][:punct:]:]*@domain.com DROP
example 2:
weber[:[:alnum:][:punct:]:]*@domain.com REJECT
- DROP / REJECT
DROP = Reject and drop the message without warning the sender
REJECT = Reject the message and send an warning to the sender
- Reload the postifx's service
service postfix reload
Would be good to make a backup of main.cf file before any change.
