i try to add Auto-Release Link into Spam Report.
I get the Spam Report but when i added a Link mailscanner/auto-release.php
=> i just get a "No Access" Info.
How can i change it?
How to add Auto-Release Link into Spam Report
Re: How to add Auto-Release Link into Spam Report
I'm assuming you set this?
define('AUTO_RELEASE', true);
Thank you for this information.
I checked it.
This Option is set to true.
I guess i have to add something in:
/usr/share/MailScanner/reports/de/recipient.spam.report.txt
I think i have to add something like:
https://<dnsNameToEfa/MailScanner/auto-release.php?id=$id
But when i open this i get the Message:
+ No Access to this Site
I checked it.
Doing it inline was deprecated in v3 and removed in v4.
So it is in efa4 not possible to add an auto-release link in SPAM Report?
=> Where i can find such Info? Do you have the link to it?
Alternatively you can use the daily MailWatch quarantine report, which you can also adjust via cron to send multiple times a day.
