Hi.
In the phase of having side by side migration of EFA 3.x to EFA 4.x
We will be probably migrating components and custom settings one-by-one (WHITELISTS, DMARC, DKIM, FAIL2BAN settings).
Is there any good tutorial how to migrate DKIM,DMARC settings?
with best regards
B
Any instructions how to manually move DKIM and DMARC
Re: Any instructions how to manually move DKIM and DMARC
https://wiki.efa-project.org/doku.php?i ... m_v3_to_v4
opendmarc migration should be similar to opendkim
Here are my v3 to v4 upgrade notes that may be of some use.
viewtopic.php?f=5&t=4325
I don't recall doing anything special for dmark, other than updating the configuration file.
I see a lot of differences in config for DKIM in EFA 3.x comparing to EFA 4.x fresh installation.
Comparison of files:
EFA 3.x (FILE: /etc/opendkim.conf)
## opendkim.conf -- configuration file for OpenDKIM filter
AutoRestart Yes
AutoRestartRate 10/1h
Canonicalization relaxed/simple
ExternalIgnoreList refile:/etc/opendkim/TrustedHosts
InternalHosts refile:/etc/opendkim/TrustedHosts
KeyTable refile:/etc/opendkim/KeyTable
LogWhy Yes
Mode sv
PidFile /var/run/opendkim/opendkim.pid
SignatureAlgorithm rsa-sha256
SigningTable refile:/etc/opendkim/SigningTable
Socket inet:8891@localhost
Syslog Yes
SyslogSuccess Yes
TemporaryDirectory /var/tmp
UMask 022
UserID opendkim:opendkim
EFA 4.x fresh install (FILE: /etc/opendkim.conf)
Selector default
## Specifies the minimum number of key bits for acceptable keys and signatures.
MinimumKeyBits 1024
## Gives the location of a private key to be used for signing ALL messages. This
## directive is ignored if KeyTable is enabled.
#KeyFile /etc/opendkim/keys/default.private
## Gives the location of a file mapping key names to signing keys. In simple terms,
## this tells OpenDKIM where to find your keys. If present, overrides any KeyFile
## directive in the configuration file. Requires SigningTable be enabled.
# KeyTable /etc/opendkim/KeyTable
## Defines a table used to select one or more signatures to apply to a message based
## on the address found in the From: header field. In simple terms, this tells
## OpenDKIM how to use your keys. Requires KeyTable be enabled.
# SigningTable refile:/etc/opendkim/SigningTable
## Identifies a set of "external" hosts that may send mail through the server as one
## of the signing domains without credentials as such.
# ExternalIgnoreList refile:/etc/opendkim/TrustedHosts
## Identifies a set "internal" hosts whose mail should be signed rather than verified.
# InternalHosts refile:/etc/opendkim/TrustedHosts
## Contains a list of IP addresses, CIDR blocks, hostnames or domain names
## whose mail should be neither signed nor verified by this filter. See man
## page for file format.
# PeerList X.X.X.X
## Always oversign From (sign using actual From and a null From to prevent
## malicious signatures header fields (From and/or others) between the signer
## and the verifier. From is oversigned by default in the Fedora package
## because it is often the identity key used by reputation systems and thus
## somewhat security sensitive.
OversignHeaders From
## Instructs the DKIM library to maintain its own local cache of keys and
## policies retrieved from DNS, rather than relying on the nameserver for
## caching service. Useful if the nameserver being used by the filter is
## not local.
# QueryCache yes
- I can't remember how I did or where did I take configuration steps for configuring DKIM/DMARC on EFA 3.x, I think it was somewhere on this forum ...
- Instructions on "https://wiki.efa-project.org/doku.php?i ... m_v3_to_v4" have a step:
cp -ra /mnt/etc/opendkim/* /etc/opendkim (answer yes to overwrite)
but we don't have /mnt/etc/opendkim
[root@efa mnt]# find / -name opendkim
/var/spool/opendkim
/var/lock/subsys/opendkim
/var/run/opendkim
/usr/sbin/opendkim
/usr/local/share/doc/opendkim
/usr/local/share/doc/opendkim/opendkim
/usr/local/sbin/opendkim
/usr/local/src/opendkim-2.4.2/opendkim
/usr/local/src/opendkim-2.4.2/opendkim/.libs/opendkim
/usr/local/src/opendkim-2.4.2/opendkim/opendkim
/usr/local/src/opendkim-2.4.2/contrib/init/generic/opendkim
/usr/local/src/opendkim-2.4.2/contrib/init/redhat/opendkim
/usr/local/src/opendkim-2.4.2/contrib/init/solaris/opendkim
/usr/local/include/opendkim
/etc/sysconfig/opendkim
/etc/rc.d/init.d/opendkim
/etc/opendkim
AutoRestart Yes
LogWhy Yes
Mode sv
Syslog Yes
SyslogSuccess Yes
UMask 022
Selector default
MinimumKeyBits 1024
# PeerList X.X.X.X
## not local.
# QueryCache yes
/var/spool/opendkim
/var/run/opendkim
/usr/sbin/opendkim
/etc/opendkim
How can dkim/dmarc inbound/outbound mail flow be tested @pdwalker ?
Apologies, I've been away from the forums for a while.
Answer to follow as I have to look it up myself again.
Hi.
Thank you for your reply.
With the help of Shawn on IRC chanell #efa-project I had sucesssfully moved DKIM and DMARC to EFA 4.x
On DMARC I didn't have to do anything special, for DKIM I had copied the keys and compared&merged dkim.conf efa3 vs efa4. Alll good!
With best regards
BostjanC
With best regards
BostjanC
There's an IRC channel?
Glad to hear you have everything working.
Yep, and Shawn is very responsive on that IRC channel:
https://wiki.efa-project.org/doku.php?id=irc_channel
