Centos 8 - efa installation - root user
bostjanc
Post by bostjanc »
Hi.
After completing efa installation wizard on fresh centos 8 my previous root username and password does not work any more.
This is probably intentional setup behaviour, but how can you update server after that with yum command.
If I try to do it it says it needs root user.
https://drive.google.com/file/d/1aagyzi ... sp=sharing
jmyk007
Re: Centos 8 - efa installation - root user
Post by jmyk007 »
You may change the root password after completing the EFA setup.
sudo passwd root
Then enter you're new password for root. As per reading, there is no effect in EFA doing this.
